July 21, 2009, 09:09 |
interFoam with irregular Mesh
Luther Terblanche
Rep Power: 17 |
Hallo,
Is it possible to use interFoam with a tetrahedral mesh or is it only designed for hexahedral meshes. I can get a simple case to run with tetra, but it crashes after a while. With the same geometry and input conditions, but with a hex mesh it works fine. All the examples and other work I see of interFoam is with hex meshes. If someone can please shed some light I would appreciate it. Kind Regards Luther |
July 21, 2009, 09:56 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Luther
From the point of view of OpenFOAM, I cannot see any limitations in interFoam, hence it must be a problem with your setup, which makes it unstable with tets. If you could describe your problem in more details, e.g. with figures, I might be able to help. Best regards, Niels |
July 21, 2009, 10:15 |
Ulrich Heck
Rep Power: 17 |
Hi Luther,
also from my experience interFOAM works much better with hex-meshes than with tet-meshes. I think one reason is that the element growth rate in tet meshes can be rather high. So I made better experience with tet meshes providing a smoother transition (propagation rate). But this may result in rather large meshes... Ulrich |
July 21, 2009, 10:34 |
Luther Terblanche
Rep Power: 17 |
Thank you Niels,
I will have a thorough look at my setup again and if the problem stil persists I will mail you the case and you can see if you find anything wrong. Kind Regards Luther |
July 21, 2009, 22:54 |
Jitao Liu
Rep Power: 17 |
Hi Luther,
I met the same problem when using the interFoam solver. The result was ok with hex-meshes. When I used tet-meshes for the same case, the courant number became bigger and bigger, then the calculation stopped. Maybe, it is caused by the non-uniform tetrahedral mesh. I will pay more attention to it. If there are any new developments, please let me know. Kind Regards Jitao |
July 22, 2009, 02:53 |
Julien Schaguene
Rep Power: 17 |
Hi Luther,
I use almost every time interFoam for my work. At first, I tried it only with hex mesh, and had no issue. Then I tried the same cases with tet mesh. At first it crashed, but since I pay more attention in meshing, I do not face this kind of problems. So be carefull in meshing and there is no reason your simulation crashes because of mesh (I think...) Regards Julien |
July 22, 2009, 04:23 |
Sebastian Gatzka
Rep Power: 20 |
My experience with non-orthogonal grids is to make sure you use corrected schemes!
You can also try to increase the number of non orthogonal corrector loops (nOrthogonalCorrectors).
Schrödingers wife: "What did you do to the cat? It's half dead!" |
August 14, 2009, 01:20 |
Cem Albukrek
Rep Power: 17 |
Don't waste time with tetrahedral grids for the interFoam class solvers by playing with correctors, schemes and etc. I wasted weeks trying to get things to work with tets and results were far from satisfactory = the effort is not worth it. Just go with hexes if you can.
August 14, 2009, 02:43 |
#9 |
Luther Terblanche
Rep Power: 17 |
Thank you. I have the same experience. Do you perhaps know about any literature where I can read up on the cause of this phenomenon?
August 14, 2009, 07:43 |
#10 | |
Sebastian Gatzka
Rep Power: 20 |
http://www.cfd-online.com/Forums/ope...-than-tet.html It's post #9 ...
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
ICEM clustering of mesh points and multiple edges | webhaw | CFX | 4 | July 25, 2007 16:29 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
