installing v1.6 and keeping v1.5
Old   July 31, 2009, 09:33
Default installing v1.6 and keeping v1.5
Gavin J. Pringle
Gavin is on a distinguished road
Send a message via Skype™ to Gavin
I've installed v1.5 on HECToR, the Cray XT4 in Edinburgh, UK, and it appears to be working fine, with
../OpenFOAM/OpenFOAM-1.5
../OpenFOAM/ThirdParty
as expected.
I now plan to install v1.6 in my OpenFOAM directory tree, so that my tree would become
../OpenFOAM/OpenFOAM-1.6
as expected.
However, v1.6 comes with an updated version of ThirdParty.
Is v1.6's ThirdParty backwards compatible? In other words, if I get rid of
v1.5's ThirdParty directory and replace it with v1.6's ThirdParty directory,
will v1.5 still work (perhaps after recompiling/relinking)?
Alternatvely, do I need v1.6's ThirdParty to run v1.6 or can I simply use
v1.5's ThirdParty?
Cheers,
Gavin
Gavin is offline   Reply With Quote
Old   July 31, 2009, 09:47
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
I think you wont have any problems, mainly because OF 1.6 creates a ThirdParty-1.6 directory, so it wont conflict with ThirdParty from 1.5.
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   July 31, 2009, 11:13
Julien Schaguene
Schag is on a distinguished road
Is he not going to have conflict for application names? (e.g. interFoam?)
I'm also interested...
Schag is offline   Reply With Quote
Old   July 31, 2009, 11:18
santos's Avatar
Jose Luis Santos
I dont think so, because you will source a different config file in your .bashrc depending on the OF version you want to run (1.5 or 1.6). That way, you will either use 1.5 or 1.6 applications.
.bashrc line:
. $HOME/OpenFOAM/OpenFOAM-1.6_or_5/etc/bashrc
Regards,
Jose Santos
Old   July 31, 2009, 11:29
Ahmed
Ahmed is on a distinguished road
the point to consider is sourcing the correct bashrc for each version, bashrc for version 1.5 will look for ThirdParty but bashrc for version 1.6 will look for ThirdParty-1.6
good luck
Ahmed is offline   Reply With Quote
Old   July 31, 2009, 11:57
Rishi .
hellorishi is on a distinguished road
Bit caution.
cmake is apparently missing from ThirdParty-1.6
http://www.cfd-online.com/Forums/ope...rty-1-6-a.html
regards,
Rishi
hellorishi is offline   Reply With Quote
Old   October 22, 2009, 03:00
Default Same problem
bigred's Avatar
Matthew Philpott
bigred is on a distinguished road
.bashrc line:
Regards,
Jose Santos
So do you have to change the .bashrc everytime you want to use a different version or can you put two lines in the .bashrc? ie.
. $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
CAELinux 2009 + OF1.5
Ubuntu 9.04 x64 (jaunty jackalope) + OF1.6
bigred is offline   Reply With Quote
Old   October 22, 2009, 20:50
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
I don't think so. Using the method, you can only use 1.6.
A possible method is
make a new file named OpenFOAM15 and put the following line in
source . $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
and put the file "OpenFOAM15" in a dir that system can found, for instance $HOME/bin
similarly, make a new file named OpenFOAM16 and put the following in
source . $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
and put "OpenFOAM16" in $HOME/bin
Once you want to change the version, Just use following line in cmd to update environment.
source OpenFOAM15 //change to version 1.5
source OpenFOAM16 //change to version 1.6
Junwei
su_junwei is offline   Reply With Quote
Old   October 23, 2009, 02:37
bigred's Avatar
Matthew Philpott
sounds like a good idea, I'll give it a try on the weekend, thanks.
Old   October 23, 2009, 04:16
Jean-Peer Lorenz
jploz is on a distinguished road
I can confirm that sourcing different resource files enables you to run
multiple OpenFOAM versions beside. I'm even using the whole set of ThirdParty stuff from the 1.6.x version with 1.5, 1.5-dev and 1.6.x, including Paraview 3.6.1. I've just created a symbolic link before compiling (each) OF - without any problems so far.
Bye,
Jean-Peer
jploz is offline   Reply With Quote
