Andrew Baglin
Rep Power: 0 ![]() |
Hi All,
I am trying to run some free surface cases using interFoam where I have 1 atm of pressure in the air and 2 atm of pressure in the water. The geometry is small enough such that the pressure difference should be accounted for by the surface tension of the water. At present I am setting the two pressures in the initial conditions, however after the first timestep, the patched pressure has disappeard and all i have is the hydrostatic pressure from the water. Am I missing something or is interFoam not capable of dealing with a discontinuous pressure. Thanks Andrew |
Pressure Condition | sidd | Siemens | 0 | April 2, 2007 09:31 |
measured pressure in the discharge pipe jumps | Jan | Main CFD Forum | 1 | October 30, 2006 07:54 |
Setting pressure and velocity in inlet | Asghari | FLUENT | 5 | September 22, 2006 13:23 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Pressure Boundary Problems | Chris | Siemens | 2 | June 21, 2005 08:20 |
