Inlet varying with time
Old   August 28, 2009, 03:59
Default Inlet varying with time
jhegar
jorgehegar is on a distinguished road
hello everybody!!
I have to simulate a pipe in which the water flow input depends on the time. What I´m trying, is to set a velocity in the inlet path that changes with the time (my problem is inkompressible). But I have no idea how I can do this. And by the moment I have not found any usefull information that could help me with this task.
Could any one there help me with this problem??
Thank´s for your time and help.
jorgehegar is offline   Reply With Quote
Old   August 28, 2009, 04:25
Julien Schaguene
Schag is on a distinguished road
did you make a search on the forum? I think this topic had been discuss before.
From what I read before, there are multiple solutions:
- the one I'm using, modifying inlet velocity at each time step by adding a piece of code in the solver.
- groovyBC should also give a solution
- I also read about timeVaryingInlet but I never tried it.
If you want some advices to "modify" the solver (in fact, just adding an include), you can mp me.
regards,
Julien
Schag is offline   Reply With Quote
Old   August 31, 2009, 03:59
jhegar
thank you very much. I will try with groovyBC, anyway I´ll ask you for some advices on modifying the solver, because I think that in some moment I will need to do it.
Thank you very much for your help.
Have a nice week.
Jorge
Old   August 31, 2009, 04:50
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Here's a bc I use for time-varying conditions.
bc_whatever
type timeVaryingFlowRateInletVelocity;
fileName "inlet1.dat";
flowRate 0.1944;
outOfBounds repeat;
value uniform ( 0 0 0 );
the inlet1.dat file is placed in the case directory and for me it looks like this
(0 0)
(13.89e-3 0.1944)
(27.78e-3 0)
(100.0e-3 0)
this will produce a triangular inlet wave with 27.83 ms duration, every 100 ms.
copy/paste from the bc-file found at src/finiteVolume/fields/fvPatchFields/derived/timeVaryingFlowRateInletVelocity
    Example of the boundary condition specification:
    @verbatim
    inlet
        flowRate        0.2;         // Volumetric/mass flow rate [m3/s or kg/s]
        value           uniform (0 0 0);  // placeholder
        fileName        "$FOAM_CASE/time-series";
        outOfBounds     repeat;           // (error|warn|clamp|repeat)
    @endverbatim
Note
    - The value is positive inwards
    - may not work correctly for transonic inlets!
    - strange behaviour with potentialFoam since the U equation is not solved
niklas is offline   Reply With Quote
time dependent inlet subroutine. HELP!!! jimmer Siemens 4 November 10, 2008 08:49
time varying inlet velocity Zhe Liu CFX 0 July 31, 2008 06:56
sinsoudial time varying BC cfd-student CFX 4 May 1, 2008 19:06
Time Varying Boundary Conditon ashish CFX 3 February 15, 2005 06:21
