calcMassFlow - problem in v1.6
Old   September 21, 2009, 13:10
Default calcMassFlow - problem in v1.6
Vojtech Betak
betakv is on a distinguished road
Hi everyone,
I've compiled successfully on my PC ( IntelCore2, OpenSuse 11.1 x86-64 ) calcMassFlow function. But after restart my PC give me this function the following error message ( in the moment when it starts compute fluxes on faceZones )
Time = 100
Flux at inlet = [1 0 -1 0 0 0 0] -0.033852
Flux at outlet = [1 0 -1 0 0 0 0] 0.0338555
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/vbetak/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/vbetak/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::FaceSetUtilities::checkFaceSetSides(Foam::fv Mesh const&, Foam::faceSet&) in "/home/vbetak/OpenFOAM/vbetak-1.6/lib/linux64GccDPOpt/libcellFaceSetUtilities.so"
#4 main in "/home/vbetak/OpenFOAM/vbetak-1.6/applications/bin/linux64GccDPOpt/calcMassFlow"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Unauthorized access to memory (SIGSEGV)
Please can you give me an advice how can I repair this error.
Thank you a lot.
Vojta
betakv is offline   Reply With Quote
Old   September 21, 2009, 15:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by betakv View Post
Hi everyone,
Time = 100
Thank you a lot.
Vojta
There are several versions of that utility floating around. Where did you get yours? I think I remember that there was a problem with the changed length of the neighbour()-field (it used to be all faces but is now only the internalFaces). The fix is rather easy, but I don't know if it is already in one of the publicly available versions
Bernhard
Old   September 22, 2009, 01:28
Vojtech Betak
Bernhard
Hi Bernard,
I've downloaded this version from http://openfoamwiki.net/index.php/Contrib_calcMassFlow
Vojta
Old   September 22, 2009, 12:45
Assistant Moderator
Bernhard Gschaider
Hi Bernard,
Vojta
I'm afraid that is the most recent publicly available version. I will look around and upload an updated version later this week
Old   August 20, 2010, 07:13
Default calcMassFlow for 1.6
Raghavendra
raagh77 is on a distinguished road
Send a message via Yahoo to raagh77 Send a message via Skype™ to raagh77
Hi All,
I would like to know where I can download the utility to calculate mass flow rate calcMassFlow for version 1.6
Regards
Raghu
raagh77 is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
convergence problem Trushar Phoenics 5 August 27, 2002 23:40
