Fluctuating pressure field
Old   October 16, 2009, 09:47
Exclamation Fluctuating pressure field
varun
vw.cfd is on a distinguished road
I am performing a two phase simulation with rasCavitatingFoam for a 'pie' shaped section of a cylinder. I have a few questions reagarding the fluctuating behaviour of the pressure field at the inlet.
  • Why do you think the pressure field is still fluctuating although the residuals look small enough?
  • Can this be overcome by using a non-reflective boundary condition at inlet? If so is it possible to implement the same with openfoam.
Suggestions are welcome.
ThanX!!!
Varun
p.s: The courant number used for the computuation is 0.2 and i have employed a k-omega+SST turbulence model.
vw.cfd is offline   Reply With Quote
Old   February 8, 2011, 06:12
Bertrand Delvaux
Bertrand is on a distinguished road
Did you find any answer about a non-reflective boundary condition? Because I would be interested as well.
Regards,
Bertrand
Bertrand is offline   Reply With Quote
cavitation, convergence, fluctuation
moving (dynamic) mesh gives fluctuating pressure daniel FLUENT 1 July 31, 2010 14:32
custom pressure field at the faces Souviktor FLUENT 0 April 3, 2009 08:09
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
order of magnitude analysis atit koonsrisuk Main CFD Forum 3 July 27, 2000 11:59
