Running stably with a large Courant number using pimpleFoam
Old   October 23, 2009, 16:14
Default Running stably with a large Courant number using pimpleFoam
Michael Lawson
mlawson is on a distinguished road
I am attempting to simulate laminar incompressible pulsatile flow in a complex geometry. To adequately resolve my geometry I need at least 15 million cells. I am driving the flow by setting the pressure and the outlet and oscillation pressure at the inlet.
Currently I am using pimpleFoam with automatic timestep adjustment to maintain a max Courant number of 2. Using a higher Courant number causes the solution to become unstable.
My problem is that at a max Courant number of 2 my timesteps are between 1E-5 and 1E-6 seconds. I need to simulate at least 1 second of time, which would require at least 100,000 timesteps at my current timestep. Given the size of my model, solving this many timesteps is computationally prohibitive.
I'm using fvSolution and fvSchemes dictionaries directly from the pimpleFoam tutorial in OF-1.6 (see attached).
Does anyone have any suggestions on how I could increase my timesteps by a couple orders of magnitude to make this simulation feasible? Should I be using a different solver? Should I be using a different discretization scheme?
Any help would be appreciated,
-Mike
mlawson is offline   Reply With Quote
Old   July 13, 2012, 06:04
Julien
Djub is on a distinguished road
Hi Mike,
Did you solve your problem?
I am trying to run a case with a very large Reynolds number (2.5e8). So I would like also to run with a large Co (Courrent flow) to limit my time calculation.
Does anyone has a solution? Or maybe an explanation that what I am looking for does not exist (and cannot exist)? Maybe the Co cannot be greater thant 1 in an unsteady flow?
In that case, is there in OpenFoam any Explicit algorithm for unsteady, incompressible, turbulent, newtonian flow ?
Djub is offline   Reply With Quote
Old   November 24, 2014, 09:27
crixman's Avatar
Christian
crixman is on a distinguished road
Dear all, any news on this topic?
I was wondering if there was a way to detach Co from the pimple solver, being able to use fixed (and larger!) time steps, as I think it's done in Fluent or other solvers.
Any ideas or suggestions?
crixman is offline   Reply With Quote
Old   November 24, 2014, 10:25
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Use first-order schemes. With upwind scheme I was able to run a case (quite simple - von Karman vortex street) with Co up to 50.
alexeym is offline   Reply With Quote
Old   November 24, 2014, 12:05
crixman's Avatar
Christian
Interesting to know, did you use turbulence schemes as well?
I could give it a try to start the simulation then switch to second order schemes, even if I'm not sure that the Co jump will be too big to be handled by the solver then!
Old   November 24, 2014, 14:11
Alexey Matveichev
No, simulation was at rather low Re (100).
Old   November 24, 2014, 16:32
crixman's Avatar
Christian
I'm making an extreme test, I'll keep you updated if I could reach an interesting value of Co (turbomachinery with kOmegaSST)!
Old   November 24, 2014, 17:13
Tobi's Avatar
Tobias Holzmann
Hi, you should Check the pimple stuft at the Wikipedia Site.
Keep foaming,
Tobias Holzmann
Old   November 24, 2014, 17:28
crixman's Avatar
Christian
Hi Tobi, sure, wanted to learn more and try out to see how far I can push it!
Old   November 24, 2014, 17:33
Tobi's Avatar
Tobias Holzmann
It Is also in my blog.
And before I ment the open foam wiki
Keep foaming,
Tobias Holzmann
Old   November 24, 2014, 17:38
crixman's Avatar
Christian
I will look it through thanks and post some updates as soon as I got time!
Old   November 29, 2014, 10:37
crixman's Avatar
Christian
Hi Tobi, I read through your post about Pimple and I am now running at Co=12.5 and everythign seems to converge well!
As I am using upwind schemes for U,k and omega, when switching to linear schemes, should I drop my Co below 1?
pimplefoam
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number msrinath80 OpenFOAM Running, Solving & CFD 1 May 29, 2006 17:20
ENO scheme and Courant number. J. Main CFD Forum 2 November 8, 2002 17:07
