trouble with totalTemperature BC
Like Tree1Likes
  • 1 Post By pg22
Old   October 26, 2009, 14:34
Default trouble with totalTemperature BC
Paul Garlick
pg22 is on a distinguished road
I am using OF1.5 and rhopSonicFoam for a compressible external flow case. On the far field boundary I would like to apply a totalTemperature boundary condition:
topBoundary
type totalTemperature;
T0 uniform 300;
U U;
phi phi;
psi psi;
gamma 1.4;
value uniform 300;
I find that solver aborts with the following message:
request for volVectorField U from objectRegistry region0 failed
available objects of type volVectorField are
0
I have found that a totalPressure boundary condition (with fixedValue for T) runs for a short time before inflow leads to rapid divergence.
In the source files for totalPressure and totalTemperature I see that the vector field for velocity is accessed in a different way in each case:
For totalTemperatureFvPatchScalarField.C:
const fvPatchVectorField& Up =
patch().lookupPatchField<volVectorField, vector>(UName_);
For totalPressureFvPatchScalarField.C:
void totalPressureFvPatchScalarField::updateCoeffs()
updateCoeffs(patch().lookupPatchField<volVectorField, vector>(UName_));
Can anyone explain why the former BC fails and the latter
succeeds; and even suggest a solution?
Many thanks.
pg22 is offline   Reply With Quote
Old   October 27, 2009, 10:15
Paul Garlick
More information ...
I noticed from the log file (for rhopSonicFoam > log) that the totalTemperature BC causes the solver to abort after writing the message:
Reading field T
This message comes from the header file "createFields.H". There is a function T.correctBoundaryConditions() that is called before the vector field for U is established. The fields are created in the order p, T, psi, rho, U, rhoU, rhoE, phiv.
My question is; may I re-arrange the code so that the vector field for U is created before T.correctBoundaryConditions() is called? The order could be p, U, T, psi, rho, rhoU, rhoE, phiv, for example.
Old   October 28, 2009, 13:28
Andrew Godfrey
agodfrey is on a distinguished road
Sorry, I can't help any, but I'm clawing my way through these bcs also. Any idea what psi and phi represent? I assume phi is the mass flux vector (rho U). Also, in the code, there's a 1 - pos(phip). Any idea where pos() is defined or what it does?
agodfrey is offline   Reply With Quote
Old   October 28, 2009, 13:38
Andrew Godfrey
Found the pos() function in Doxygen.
00103 inline Scalar pos(const Scalar s)
00104 {
00105 return (s >= 0)? 1: 0;
00106 }
I still don't know what phip is though. I assume it's negative though, or else the bc isn't very useful.
Old   October 28, 2009, 15:54
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
00104 {
00106 }
phip: phi on a patch. The definition of phi (mass flow on the face) has been discussed a number of times. Sign says whether it's flowing in or out
gschaider is offline   Reply With Quote
Old   October 28, 2009, 20:18
Andrew Godfrey
Thanks Berhard. Saw several of your talks in Montreal last June. I figured the phi part out after the post. From the code, psi must equal rho/p, but I don't know why or how this bc's dictionary works. Why is U part of the class?
Old   October 29, 2009, 04:39
Assistant Moderator
Bernhard Gschaider
Never worked with that boundary condition. But I guess for multiphase-solvers where more than one velocities exist
Old   October 29, 2009, 05:49
Paul Garlick
Have made some progress with this problem...
First, I re-ordered the creation of the fields defined in "createFields.H". I used the order I mentioned above; p. U, T, psi, rho, rhoU, rhoE, phiv. I re-compiled and found that the solver aborted again, this time on searching for the scalar field phi.
Then I moved the T.correctBoundaryConditions() function down in the file, to the line below rhoU.correctBoundaryConditions().
I re-compiled and the solver ran successfully. However, in order to update the boundary condition after each time step one extra change is needed:
in rhopSonicFoam.C I added the update function just below the expression for U;
U=rhoU/rho;
T.correctBoundaryConditions();
I have re-compiled rhopSonicFoam and it works fine; the temperature at the far field boundary is adjusted as pressure waves move through and the local velocity changes.
To answer the question on why U is involved, the totalTemperature function is simply
an expression of the energy equation; as the velocity increases the temperature drops.
FrankFlow likes this.
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 18:54
Finned Pipe Trouble fabioxyz CFX 8 August 31, 2009 02:20
trouble with squeezing mesh adrianahscott OpenFOAM Running, Solving & CFD 0 August 29, 2009 07:25
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 11:22
Could anybody help the trouble of the modifying the U liugx212 OpenFOAM Running, Solving & CFD 2 February 27, 2006 10:23
