Difference between fluentMeshToFoam and Fluent3DMeshToFoam
Like Tree1Likes
  • 1 Post By doubtsincfd
Old   November 27, 2009, 07:29
Default Difference between fluentMeshToFoam and Fluent3DMeshToFoam
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
Hello all. I am new here and I'd like to greet you all.
I have been working with OpenFOAM for the last couple of months. I have set up a few simple cases and parallel processing and I am getting deeper into it.
I have been wondering what is the difference between fluentMeshToFoam and fluent3DMeshToFoam. As far as I can see, there is not any significant difference. Is this correct? In which cases should one use one command or the other?
Thank you.
thekay is offline   Reply With Quote
Old   November 28, 2009, 12:37
Francesco Del Citto
fra76 is on a distinguished road
fluentMeshToFoam is the old code. It can handle 2D Fluent meshes but struggles with some 3D meshes (for example, meshes with hanging nodes)
fluent3DMeshToFoam is newer. Can handle only 3D meshes, but it does this much better than the old one. If you have a 3D mesh, this has to be preferred, in my opinion.
Hope this helps,
Francesco
fra76 is offline   Reply With Quote
Old   November 29, 2009, 16:22
Costas K
Thank you. This was helpful. I will come back to this thread if I have more questions.
Old   January 17, 2013, 10:38
Default How to use fluentMeshToFoam or fluent3dMeshToFoam?
Ali Khalifesoltani
asoltoon is on a distinguished road
Hello guys,
How can I use this function? when I write "fluentMeshToFoam <e.g. myFileName>" it says "bash: syntax error near unexpected token `newline' " .
Is there any package to be installed? If yes, how?
Thanks in advance.
asoltoon is offline   Reply With Quote
Old   January 17, 2013, 10:43
Default Solved
Ali Khalifesoltani
I wrote the incorrect syntax, it should be like this:
"fluent3DMeshToFoam filename.msh"
Old   January 18, 2013, 11:00
doubtsincfd is on a distinguished road
Also, for cyclic patches fluent3dMeshToFoam writes the patches in the ordered way but fluentMeshToFoam does not. I had experienced this in v2.0. Please verify if this behavior is still the same.
Haitham Osman CFD likes this.
doubtsincfd is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[Commercial meshers] Error fluentMeshToFoam loneboard OpenFOAM Meshing & Mesh Conversion 26 February 6, 2009 10:20
