Gamma / MPI
Old   February 23, 2010, 15:42
Default Gamma / MPI
Jason Ryon
jason.ryon is on a distinguished road
Sorry for the beginner question:
I have seen multiple posts about how using Gamma MPI is beneficial to improving parallel efficiency.
1. How do I see what MPI (gamma, openmpi, etc...) I am using?
2. How do I change it to something else (gamma for example) in OpenFOAM 1.6? From what I read, it is something like:
a. Edit ~OpenFOAM/OpenFOAM-1.6/etc/bashrc to be "gamma" instead of openmpi in the "WM_MPLIB"
b. cd $FOAM_SRC/Pstream
c. ./Allwmake
Now when I try to decomposePar it says:
decomposePar: error while loading shared libraries: libPstream.so: cannot open shared object file: No such file or directory
Can somebody please point me to how to install gamma mpi and also set it up with OpenFOAM 1.6?
Thanks,
Jason
jason.ryon is offline   Reply With Quote
Old   February 24, 2010, 04:41
BastiL
bastil is on a distinguished road
From what I know:
1. It only makes really sence on ethernet clusters no ib or similar
2. last recommendation was to use open-mx instead of gamma since it is much easier to compile.
TO use it build open-mx (http://open-mx.gforge.inria.fr/) from source and afterwards compile openmpi against open-mx.
Regards
bastil is offline   Reply With Quote
Old   February 24, 2010, 12:04
Jason Ryon
Does Gamma effect parallel scalability on a single node (i.e. from 2 to 3 to 4 cores on a single processor)?
I am still in the single-box testing phase before I get to ethernet or ib.
Thanks,
Jason
gamma mpi
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
OpenCFD enhances OpenFOAM's parallel communications OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 October 2, 2006 08:36
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
