reactingFoam boundary conditions
Like Tree6Likes
Old   March 10, 2010, 11:58
Default reactingFoam boundary conditions
pas32 is on a distinguished road
I'm simulating the combustion of hydrogen with a burner in atmospheric air and I have problems with the boundary conditions.
I did a 2D representation of the environment at the burner exit with a symmetry plan in the middle of the burner. Which boundary condition sould i use where the boundary is air? outlet or inletoutlet? Where do I define the temperature and pressure of the environment?
I am new with OpenFOAM and i hope someone can help.
Thank you
fuguang likes this.
pas32 is offline   Reply With Quote
Old   March 10, 2010, 21:21
Karl-Johan Nogenmyr
kalle is on a distinguished road
For pressure I would use:
airBC
type totalPressure;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
p0 uniform 100000;
value uniform 100000;
For Velocity I would use:
airBC
type fluxCorrectedVelocity;
phi phi;
rho rho;
value uniform (0 0 0);
And for other scalars I would use zeroGradient
Good Luck!
fuguang likes this.
kalle is offline   Reply With Quote
Old   March 11, 2010, 11:24
Thanks.
But what about the temperature? How do I indicate that the ambiant temperature at the boundary is 295K?
Old   March 11, 2010, 18:40
Karl-Johan Nogenmyr
Well, you can always force scalars (T, Yi) to be like surrounding values (air at 295K), but if you get a piece of hot product gases or so at the outflow boundary, you might get divergence due to strong gradients. If you put initial conditions correctly, it is likely that values will remain good at the boundary.
Will you use both an atmospheric BC and a separate outlet BC where you think that the products will leave? I would use the above mentioned BC's at the whole 'outlet' i.e. not use a separate outflow BC together with an atmospheric BC.
fuguang likes this.
Old   March 12, 2010, 14:15
I applied the atmospheric boundary like you mentionned to all the "outlet" for p and U and I left the rest with zero gradient. Unfortunately, when I ran the problem without combustion (just hydrogen entering in air), it looked like if the domain was closed because it filled with hydrogen and after 2 sec of simulation, the whole grid was filled with 100% hydrogen.
Old   March 12, 2010, 23:07
Karl-Johan Nogenmyr
Hmm.. can you post your case?
Old   March 15, 2010, 12:28
Here is my case. Sorry for the delay, I didn't have my files with me over the week-end.
Thanks
Old   March 16, 2010, 00:56
Karl-Johan Nogenmyr
Thanks...
I see. You get really strong recirculation at the inlet, and this gradually fills your domain with H2. This recirculation is present in the whole domain, and if you want to simulate an open flame, you should probably do something about this... .typically move away boundaries. You can also try to set the AIR_BAS patch as an inlet and specify some small velocity that will counteract this recirculation.
Anyway, I believe the problem with filling of the domain can be avoided by using the inletOutlet BC instead of zeroGradient for scalars. That BC acts as zeroGradient when fluid is leaving the domain, but allows you to specify scalar values when fluid is entering the domain... Hence, in the attachment, I specified that air should be entering when you have inflow at your atmospeheric boundary.... Later, when you let it burn, you may want to do this for T also.
Good luck
Kalle
p.s. massfraction O2 in standard air would be around 0.23
fuguang likes this.
Old   March 29, 2010, 11:13
Thanks for the information. It now seems to work properly without the combustion.
I did some tests with combustion and i'm having some problems. Maybe you can help.
With an inlet speed of fuel at 20 m/s (laminar flow), the combustion seems to be working. I tried to reduce the speed to 0.5 m/s to reproduce simulations from an article and it wasn't working. I increased to 10 m/s and after 0.13 sec, it wrote the following:
Solving chemistry
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::derivatives(double, Foam::Field<double> const&, Foam::Field<double>&) const in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libchemistryModel.so"
#4 Foam::SIBS::SIMPR(Foam::ODE const&, double, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::SquareMatrix<double> const&, double, int, Foam::Field<double>&) const in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libODE.so"
#5 Foam::SIBS::solve(Foam::ODE const&, double&, Foam::Field<double>&, Foam::Field<double>&, double, Foam::Field<double> const&, double, double&, double&) const in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libODE.so"
#6 Foam::ODESolver::solve(Foam::ODE const&, double, double, Foam::Field<double>&, double, double&) const in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libODE.so"
#7 Foam:de<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::solve(Foam::Field<double>&, double, double, double, double) const in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libchemistryModel.so"
#8 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::solve(double, double) in "/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libchemistryModel.so"
#9 main in "/home/pouimette/OpenFOAM/pouimette-1.6/applications/bin/linux64GccDPOpt/reactingFoam"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/pouimette/OpenFOAM/pouimette-1.6/applications/bin/linux64GccDPOpt/reactingFoam"
Floating point exception
Do you know what it means?
Thanks
Pascale
fuguang likes this.
Old   March 29, 2010, 22:59
Karl-Johan Nogenmyr
The output suggests that there occurred an illegal operation (sigfpe) - typically divide by zero. I would guess it is related to the chemistry solver in this case. You can try to play around with different solvers in the 'chemistryProperties' file. You can also try setting the equilibriumRateLimiter on. To find out what is happening you can also closely monitor the solution just before the crash.
Someone else have any suggestions?
Kalle
fuguang likes this.
Old   October 2, 2011, 17:07
Gonzalo
gfoam is on a distinguished road
Can you post again the chemkin zip file (it may be damaged)? I am having the same problem with reactinFoam...I'm trying to run a case of gas mixture only to figure out how the diffusion progress in time. If somebody can help me I'm willing to upload the directories ASAP...THANKS!
gfoam is offline   Reply With Quote
Old   July 27, 2012, 04:58
Pang
kmpang is on a distinguished road
Hi Foamers,
I don't really understand the implementation of 'fluxCorrectedVelocity' B/C. May I ask how does it work? Also, how is it different from 'zeroGradient' B/C?
Best regards,
Pang.
kmpang is offline   Reply With Quote
Old   January 7, 2014, 07:24
Default Hydrogen release case
  #13
James
ni-openfoam-user is on a distinguished road
Dear colleagues,
I am new to OpenFOAM. I have completed the relevant tutorials and read through all the useful information that I can find.
I am currently starting to play and modify the tutorials to meet my goals.
I wish to start by modelling a simple generic 3D hydrogen release case, say from a simple pipe into the atmosphere.
Can anyone give me pointers about how to start modifying the tutorials to meet this goal? Any help would be greatly appreciated.
Many thanks,
James
ni-openfoam-user is offline   Reply With Quote
Old   January 8, 2014, 07:35
Default Hydrogen Release Case
  #14
Jason Dale
jason is on a distinguished road
Hi James,
Here is a simplified test case from a long time ago which I just updated to the latest OF version. I would check the properties of the gases just to be sure.
The floor wall could quite easily be your pipe wall with a hole in it and you specify the release velocity.
The H2 concentration at the injection point you change in the '0' directories for the N2, O2 and H2 concentrations (0 to 1 = 0% to 100%)
You use the reactingFoam solver but turn off chemistry and combustion so you are only considering mixing in this example case.
Try playing around with variables such as the Courant number and also the mesh density (I would think the mesh has to be quite fine at the mixing interfaces to reduce numerical diffusion). In addition, you might want to experiment with the numerical schemes.
If it were me, before even thinking about combustion or chemistry I would get the case working correctly just for mixing ... then make it more complicated.
Regards
Jason
jason is offline   Reply With Quote
Old   February 12, 2014, 12:48
Default thermo.dat
  #15
James
Jason,
Thanks again for sending me the case file, it is proving very usual for me.
I have an additional question if you don't mind.
Considering your post in the 'reactingFoam boundary conditions' thread: i.e. "The H2 concentration at the injection point you change in the '0' directories for the N2, O2 and H2 concentrations (0 to 1 = 0% to 100%)".
I understand that you can change the H2 concentration here at anything from 0 to 100% ( 0 -1).
However, if a change is made here does this change not also require a change to be made in the 'thermo.dat' file to reflect the new concentration of H2 being investigated? (considering combustion scenario)
Many thanks for taking the time to answer my queries.
Kind regards,
James
Old   February 13, 2014, 04:01
Jason Dale
Hi James,
Unfortunately I've never used reactingFoam for combustion (not my field).
But in thermo.dat you specify the coefficients for the chosen thermodynamic model (which is specified in the thermophysicalproperties file). In the example janaf was chosen so you have to specify the coefficient for this model.
I think you will find what you need to know here
http://www.openfoam.org/docs/user/thermophysical.php
Regards
Jason
Old   June 2, 2014, 13:23
Default thermo.dat 2
  #17
James
Hi Jason,
Thanks again for sending the case file it has proved very useful.
I have been able to test it and modify it, and have completed a number of low velocity release test simulations.
I am now moving on to increasing the release velocity and decreasing the orifice diameter. I am specifically looking at a scenario with a 3
mm opening and a release velocity of approximately 1000 m/s.
As you can imagine this requires quite a small timestep and a refined mesh to solve.
My question is regarding the thermo.dat file. In the vicinity of the release a partial vacuum may be created, and therefore very small temperatures. These temperatures may be lower than the range specified in thermo.dat (i.e. lower than 200).
Q1. To modify thermo.dat, is it simply a case of lowering the lower temperature range?
Q2. How is this file created? And if required how can it be modified to incorporate such low temperatures? Where do the values for "highCpCoeffs" and "lowCpCoeffs" come from and how are they calculated? (I guess from Chemkin or similar, could you please expand)
Many thanks again for your previous reply and (hopefully) thanks for taking the time to answer my queries.
Kind reagrds,
James
Old   July 7, 2014, 10:45
Default Updating older solvers to new version
  #18
James
Jason,
I am attempting to use the solver "alternateSteadyReactingFoam" for my simulations. This solver was created using v1.5. I am trying to use it with version 2.2.
http://svn.code.sf.net/p/openfoam-ex...yReactingFoam/
You previously stated that you updated the test case which you previously provided from an old to the new version of OpenFOAM.
Could you please kindly comment on the steps required to update an old solver / case to the new version of OpenFOAM?
Many thanks,
James
Old   January 17, 2023, 02:16
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Hi fellows, i will pop-up this thread again.
Currently i am trying to solve mixing (later laminar combustion) on liquid rocket motor. Species are some hydrocarbons, hcl, o2, oh, h2o so on so forth. I am using rhoreactingfoam for this, no matter steady or unsteady analysis in this step but i am doing unsteady one, slowly increasing inlet pressure, initializing domain with atmospheric conditions. At starting phase of analysis, solution seems like stable, but after some time, time step sizes reduces too much (ie. to 1e-12), so i observe no change in solution, even some variable matricies are not being solved. I am using maxco 0.5, initial stepsize 1e-7,1e-8 whatever doesnt matter at all. I am observing no recirculation at boundaries, no janaf temperature region warnings (i am limiting the numbers and expand the thermo properties until 20000K). Any idea about this strange behavior?
Thanks in advance
atelcikti1 is offline   Reply With Quote
Old   March 17, 2023, 03:43
Vahid
vahid2023 is on a distinguished road
Thanks in advance
I think it is because of a high differential gradient of parameters. I think if you set a lower fuel ratio as an inlet or use a setField to put lower fuel inside the domain this problem can be solved.
vahid2023 is offline   Reply With Quote
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 04:44
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
