StreamFunction Utility in OF1.6
Old   March 23, 2010, 04:19
Default StreamFunction Utility in OF1.6
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
Dear Foamers,
I can able to write data by using this utility "StreamFunction". When i upload this data as point Fields in paraFoam, it doesnt display.
The following message shows up.
/usr/local/OpenFOAM/OpenFOAM-1.6.x/bin/paraFoam: line 109: 4687 Segmentation fault paraview --data="$caseFile"
Any hint will be useful.
Thanks
maruthamuthu_venkatraman is offline   Reply With Quote
Old   April 12, 2010, 10:41
Dear Foamers,
Actually internal mesh has to be checked out, only boundaries should be included when we open data in paraview. Then we can see the streamfunction predicted by OpenFoam.
May be its useful to somebody.
Old   April 13, 2010, 13:55
Primoz Ternik
ternik is on a distinguished road
Originally Posted by maruthamuthu_venkatraman View Post
Dear Foamers,
Hi Maruthamuthu,
I have the same problem with OF-1.5; I am able to run streamFunction utility, but I can not load (view) results with ParaView, even if I "check out" the internal mesh! Do you (or anyone else) have any hints on this?
Thanks and enjoy,
Primoz
ternik is offline   Reply With Quote
Old   April 13, 2010, 14:27
You should include StreamFunction data aswell, Its there in point fields. Except internal mesh checkin all the rest . Atleast in OF1.6 it works .
Just try it out and reply me if it works..
Regards
Old   April 13, 2010, 15:21
Primoz Ternik
Regards
unfortunately I can not see the "streamFunction" data in the "Point Field Status" (in ParaView)!
Anyway, thanks for your reply!
Cheers,
Primoz
Old   September 28, 2011, 09:28
Default hi every one
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
i m using openfoam 201
i have problem to plot streamFunction i solved problem for laminar nonisothermal cavity flow with buoyantBoussinesqSimpleFoam.
when i run streamfunction then it gave me error but when i run another solver like icoFoam,SimpleFoam then streamfunction works but in buoyantBoussinesqSimpleFoam it cant work so what can i do?
plz tel me how can i plot streamFunction?
tel me how to plot streamFunction using buoyantBoussinesqSimpleFoam.
i found error like,
Create mesh, no clear-out for time = 0
Time: 0
--> FOAM Warning :
From function streamFunction
in file streamFunction.C at line 456
Flux field does not exist. Stream function not calculated
Time: 100
Reading field phi
Zero face: patch: 0 face: 0
#0 Foam::errorrintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/streamFunction"
#4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
abcz@abcz-desktop:~/Desktop/sample$
jignesh_thaker2007 is offline   Reply With Quote
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 18:04
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 02:00
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 0 February 5, 2010 12:12
UDF for streamfunction nisha Fluent UDF and Scheme Programming 0 September 15, 2009 06:55
streamfunction from u and v on a coarse mesh ryoga Main CFD Forum 0 February 1, 2002 18:20
