Momentum equation of interFoam?
Old   March 25, 2010, 22:16
Default Momentum equation of interFoam?
bubbles
cfdfans is on a distinguished road
Dear Foamer,
I am a beginner in interFoam of OpenFoam. I wonder if there are someone could show me how the momentum equation of interFoam in version 1.6.x is demonstrated below:
ddt(rho,U) + div(rhophi,U) = grad(P) + rho*g + fv + laplace(mueff,U)
inwhich:
fv : surface tension force
rho = alpha1*rho1+(1-alpha1)*rho2
U = alpha1*U1+(1-alpha1)*U
rhophi = rho*U + alpha1*(1-alpha1)*(rho1-rho2)*(U1-U2)
I tried from two equations of each phase, but I am not successful.
Thanks a lot.
Milou
cfdfans is offline   Reply With Quote
Old   March 26, 2010, 06:58
Claus Meister
idrama is on a distinguished road
Check the internet for Ruschke's Ph. D. Thesis!
In this forum is this thesis serveral times mentioned, just keep looking at it.
If ya can't find it, send me aderess to where I can send it!
Cheers
idrama is offline   Reply With Quote
Old   March 26, 2010, 08:14
Claus Meister
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/HenrikRuschePhD2002.pdf
Old   March 26, 2010, 11:14
bubbles
Thanks for your quick reply.
In fact, I had read Rusche's PhD thesis several times but if I wouldn't make a mistakes and what I understand is that the chapter 3: Two Fluid Methodology describes the averaged equation for each phase and the model for the last term in the averaged momentum equation; and the chapter 4: Interface capturing Methodology talks about the mometum equation for a domaine with an interface by using the indicator gamma or alpha1.
By looking all two chapters, I could not find some things similar to:
ddt(rho,U)+div(rhophi,U)=....
and how can we explain that:
Thanks for your answer.
Milou
Old   March 28, 2010, 04:17
Claus Meister
Properly you have already found it:
http://www.cfd-online.com/Forums/ope...of-method.html
In this blog there is a hot discussion on going.
Cheers,
Old   March 28, 2010, 07:54
bubbles
Dear Claus Meister,
Thanks for your indication on VOF method blog. I will go to these comments on the blog immediately.
Best regards
Old   March 28, 2010, 08:46
bubbles
Dear Claus,
I read the blog of VOF method, really, there are many comment on VOF method, especially on the gamma equation, on interface properties base on gamme discusion, on MULES...
And I found that there are the thesis of Patricio Bohorquez is very interesting, especially the definition of "mass velocity" and "volumetric velocity". But I could not find out my question there.
Thanks for your patient support.
Best regards.
Milou
Old   September 13, 2012, 15:27
einat
einatlev is on a distinguished road
see equation 4.24 in Rusche's thesis. That's the form of the momentum equation closest to the code as far as I could find.
einatlev is offline   Reply With Quote
Old   January 4, 2013, 04:44
Hossein Yahyazadeh
hossein_y62 is on a distinguished road
Originally Posted by idrama View Post
Hi idrama,
Would yo please send me the PDF file of this thesis, I cannot access to it.
Thanks
hossein_y62 is offline   Reply With Quote
Old   January 5, 2013, 03:09
Nima Samkhaniani
nimasam is on a distinguished road
you can also check this journal:
http://pre.aps.org/abstract/PRE/v79/i3/e036306
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   May 9, 2018, 02:43
Elham
Elham is on a distinguished road
Regarding to the equation(20) of
HTML Code:
https://journals.aps.org/pre/pdf/10.1103/PhysRevE.79.036306
I have checked interFoam UEqn.H. Two following terms are missing:
      - fvm::laplacian(muEff, U)
      - (fvc::grad(U) & fvc::grad(muEff))
While they are included in porousInterFoam. Anyone knows the reason?
Regards,
Elham
Elham is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
momentum equation (Normal to wall) kk Main CFD Forum 0 July 2, 2006 23:13
momentum equation (Normal to wall_ kk Main CFD Forum 0 July 2, 2006 23:10
