How to create my own functionObject ?
Old   April 23, 2010, 05:12
Default How to create my own functionObject ?
Jiang
panda60 is on a distinguished road
Dear all,
I use functionObjedt like following:
functions
extraction
type surfaces;
functionObjectLibs ("libsampling.so");
enabled true;
outputControl timeStep;
outputInterval 5;
surfaceFormat foamFile;
interpolationScheme cellPointFace;
fields
U
T
surfaces
aplane
type plane;
basePoint (-0.4 0 0.5);
normalVector (1.0 0 0);
my purpose is to extract a plane data of internal domain in every time step. But the file directory is not what I want.
I copy src/sampling ,and modify a little ,create another called libmysampling.so.
but when using, it displays:
--> FOAM Warning :
From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 68
library "libmysampling.so" did not introduce any new entries
It seems that my own libmysampling.so doesn't take effect.
Could any one tell me how to create functionObject type ?
Thanks.
panda60 is offline   Reply With Quote
Old   April 26, 2010, 23:59
Jiang
I want to modify surfaces functionObject, I found it belongs to sampling,
So I copy src/sampling directory to another position.
I changed the name to LIB = $(FOAM_USER_LIBBIN)/libmysampling.
in sampling\sampledSurface\sampledSurfaces, I found 2 places had name "surfaces",
*.H file:
public:
//- Runtime type information
TypeName("surfaces");
*.C文file:
PtrList<sampledSurface> newList
dict.lookup("surfaces"),
sampledSurface::iNew(mesh_)
I changed these "surfaces" to "mysurfaces", and compiled, no problem.
but when I used, had the following mistake,
Starting time loop
--> FOAM Warning :
Unknown function type mysurfaces
Valid functions are :
5
surfaces
fieldAverage
fieldMinMax
sets
probes
From function functionObject::New(const word& name, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 89.
FOAM exiting
It seems that my modified name haven't been registed in functionObject.
Could anyone can give me some help ?
Thanks.
I am using like this in my controlDict file:
extraction
type mysurfaces;
functionObjectLibs ("libmysampling.so");
enabled true;
outputInterval 1;
fields
U
T
mysurfaces
aplane
type plane;
Old   May 20, 2010, 12:26
Default Not able to use newly created library
Subodh Kumar
Subodh is on a distinguished road
Send a message via Yahoo to Subodh
I have created a library successfully, but I am not able to use it, It is giving error like below. Any help or input would be greatly appreciated..
Type of Error
--> FOAM Warning :
library "monitor.so" did not introduce any new entries
Unknown function type monitor
Table of functionObjects is empty
From function functionObject::New(const word& functionType, const Time&, const dictionary&)
in file db/functionObject/functionObject.C at line 75.
FOAM exiting
functionObject in ControlDict
functions
monitor
type monitor;
functionObjectLibs ("monitor.so");
inletPatches (VolImp);
outletPatches (Outflow);
rhoInf 998.0;
My Inputs/Findings/Observations
I searched over OpenFOAM forums, there were few discussion regarding this, which say if OpenFOAM-1.6 is being used then it might causing because some parameters in functionobject are missing in controlDict file. It also says error messages displayed for this problem in OpenFOAM-1.6 and OpenFOAM-1.5 are different, OpenFOAM-1.6 says as above but OpenFOAM-1.5 says "parameters are missing". Since I am using OpenFOAM-1.5 there must be another reason for this error..
Subodh is offline   Reply With Quote
Old   May 21, 2010, 02:35
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
functions
monitor
type monitor;
rhoInf 998.0;
If you try with
functionObjectLibs ("libmonitor.so");
it might work for you.
Note the 'lib' prefix when specifying the library to load.
Actually, it could be a good RFE to automatically add the 'lib' prefix and the '.so' suffix.
I just don't know how this might look on other systems though.
olesen is offline   Reply With Quote
Old   May 21, 2010, 06:55
Subodh Kumar
Thank you Olesen for suggestion..
According to your suggestion, I created a new library called libmonitor.so and loaded it in controlDict by using functionObjectLibs ("libmonitor.so"); but it is giving the same error with new library name. Below is error produced by simpleFoam. Please note when I changed functionObjectLibs ("monitor.so"); to functionObjectLibs ("libmonitor.so"); in controlDict then OpenFOAM asked for missing library so I created by name of libmonitor.so instead of monitor.so
What would you suggest in this case, should I debug simpleFoam code ??? I do not know what help I could get by debuging but since I am a software engineer I know this way only.
Type of Error
Starting time loop
--> FOAM Warning :
library "libmonitor.so" did not introduce any new entries
FOAM exiting
Old   May 25, 2010, 09:39
Subodh Kumar
I finally managed to create a library which works well.
Solution of the problem :
updateMesh(const mapPolyMesh&)
movePoints(const pointField&)
Above virtual functions have to be overridden and FuctionObjects header file and C files need to be included.
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Steps to create a quater O grid or Y grid brissyben ANSYS Meshing & Geometry 3 April 12, 2012 05:46
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
