Complex Fields
Old   May 6, 2010, 03:47
Default Complex Fields
sunil
suniljain is on a distinguished road
What would be the procedure to be able to solve for Complex (complex as in complex numbers, with a real and imaginary parts) fields.
Complex number support seems to be present in OpenFOAM, but no such thing as volComplexField, volComplexVectorField, etc.
What would be the procedure to be able to use ddt and div, grad etc schemes with complex numbers??
And finally the boundary conditions?
What will have to be done to make the solver, so that solve(...) can be used?
Has any work already gone in this direction?
suniljain is offline   Reply With Quote
Old   September 12, 2019, 08:09
gigilentini8 is on a distinguished road
This would be a great feature indeed...
but quite "complex" to implement. I wonder if there is some workaround to define solvers using separately two fields (real and imaginary part)
gigilentini8 is offline   Reply With Quote
OpenFoam and complex numbers panara OpenFOAM Pre-Processing 3 June 13, 2017 05:25
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
Programming a CFD code using complex variables New coding Main CFD Forum 1 July 3, 2008 21:32
Can Fluent deal with complex number? demigod FLUENT 2 June 27, 2005 03:53
CFD code for sort of complex fluid/solid interaction? Alton Reich, PE Main CFD Forum 3 May 29, 2000 09:33
