List/documentation of all BC/patch types of the OF solvers
Old   May 7, 2010, 07:16
Default List/documentation of all BC/patch types of the OF solvers
Christoph
kriz is on a distinguished road
being new to OpenFOAM, I am wondering if there is a list of all possible BC/type of patches (e.g. zeroGradient, fixedValue, etc.) for each solver type, accompanied with a little documentation? Using e.g. k-eps models, I have wall-functions a.s.o.
Using the text-editor for setting up my BCs and patch-types, I am completely lacking a naming-list of the BCs, I am having a hard time guessing the correct nomenclature.
I would appreciate any help!
Best regards,
Kriz
kriz is offline   Reply With Quote
Old   May 7, 2010, 07:19
Johan Spång
josp is on a distinguished road
http://www.openfoam.com/docs/user/
see chapter 5 for some information about boundary conditions and chapter 7 for information about turbulence.
Best regards,
Kriz
josp is offline   Reply With Quote
Old   May 7, 2010, 07:37
Christoph
Originally Posted by josp View Post
Thanks for the quick reply, but, of course, I have already consulted the manual. It leaves much more questions open than it answers.
There is one table on page 133 stating some BCs of different types, however, not explaining them.
For example, "turbulentInlet" "calculates a fluctuating variable based on a scale of a mean value" and I have to specify a reference Field and a fluctuation scale. So I am as lucky as before. What is the fluctuation scale? The characteristic turbulent scale? What reference field? To what variable I can specify this BC to? Velocity?
Simple example: I want to specify a fixed value velocity BC at an inlet and a fixed value pressure BC at the outlet, what do I have to specify for pressure at the inlet and for velocity at the outlet?
Old   May 7, 2010, 08:09
Johan Spång
In OpenFOAM you have to specify BC's for each equation separately
For your simple example with fixedValue U and fixedValue p on inlet and outlet see:
/home/foam/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/simpleFoam/pitzDaily
About turbulentInlet: find and grep will locate these files:
/home/foam/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/fields/fvPatchFields/derived/turbulentInlet/turbulentInletFvPatchField.H
/home/foam/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/pisoFoam/les/pitzDaily/0/U
It might give you a hint of what to do.
Perhaps someone else has more to say about this.
Old   May 7, 2010, 09:45
Christoph
Thanks a lot. There are still some (many) open questions for me:
- Why do I have to specify values for the k-eps wall-functions (nutWallFunction, kqRWallFunction, ...)? Just for initialising? Or do they have an effect on the wall treatment?
- Is nut=alphat/density?
- What the heck is nuTilda (same unit as nut)?
- What is R (same unit as turb.kin.en. k)?
- as far as I see it, I can set nut to "calculated" for inlet and outlet since it depends on k, eps and density only?
Old   May 7, 2010, 21:08
Alberto Passalacqua
A quick search on the Doxygen documentation shows this: http://foam.sourceforge.net/doc/Doxy...alarField.html
The Reynolds stress tensor.
I'd suggest you do a quick search in the doxygen manual to see how these fields are used.
Best,
Alberto Passalacqua
Old   May 8, 2010, 04:07
Christoph
Thanks, I didn't know the doxygen manual up to now. However, being only acquainted to matlab programming (and a little fortran from earlier years) I couldn't figure out where the value I have to specify for the boundary type "nutwallfunction" in the case\0\nut file is used in the nutWallFunctionFvPatchScalarField (being used when I use the nutwallfunction BC, I guess?).
Probably I have to look somewhere else (another subroutine?) to see what the solver is doing to or with the value I have to specify with the "nutwallfunction" BC?
Old   May 8, 2010, 16:54
Alberto Passalacqua
Hi, sorry for my too quick answer :-)
- When you specify nutWallFunction, the value is required, but it does not seem to be used: set it to "uniform 0".
- nut is the kinematic turbulent viscosity: mut/rho.
- Yes, using k-eps, nut is computed based on k and epsilon, so the condition at inlets and outlets can be something like
inlet
   type            calculated;
   value           uniform 0;
again with "value" required and not used.
Best,
Alberto Passalacqua
Types of solvers CFD-Junior Main CFD Forum 6 April 14, 2019 17:25
ODETest.C Compiling failed in version 1.6 sxhdhi OpenFOAM Bugs 4 April 27, 2010 05:36
network comms amg solvers bob Main CFD Forum 0 March 1, 2007 19:58
unlocking material types in ICEM CFD Evan CFX 0 July 19, 2006 16:26
PHOENICS Solvers Hu Phoenics 0 June 28, 2002 07:37
