Rep Power: 16 ![]() |
First at all, I am quite new to OpenFOAM and CFD Simulations. From a segmentation I have different meshes at different time steps (say at times 0, 0.1, 0.2, ...). Just the Position of the points change at the moment, not the amount of cells. So in my case directory I put in 0/polyMesh a points file, in 0.1/polyMesh a points file and so on. Then I ran the standard pisoFoam solver. It does work somehow and the mesh actually changes at the time steps but I don't think there is an impact of the changing mesh on the velocity and pressure variables. I found the dynamicMesh utility in the tutorials section but I guess it does something else than I want. So, is such a simulation possible and how is the correct procedure? Thanks a lot! Zymon |
Niels Gjoel Jacobsen
Rep Power: 37 ![]() ![]() |
Hi Zymon
The dynamicMesh, e.g. one of the *Dym* solvers, is what you want. The change in position of the nodal points in your model must result from some kind of motion of the boundaries. Hence describe the boundary motion to the model, and you should be able to achieve the needed results. Best regards, Niels |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
export time steps for ensemble averaging | Thomas Baumann | Siemens | 0 | March 2, 2010 03:19 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
UDF for time steps | David | FLUENT | 0 | August 14, 2007 11:54 |
Time steps - Large Eddy - LES | Gernot | FLUENT | 0 | September 14, 2005 11:54 |
