axis-symmetric case
Old   May 15, 2010, 17:23
Default axisymmetric case
Alexander
Svensson is on a distinguished road
Send a message via Skype™ to Svensson
I'm trying to simulate a simple problem - current in a pipe of constant diameter. Tried manually and using the utility makeAxialMesh to create axis-symmetric case. After start simpleFoam solver there are deduced data for 3 vector components.
Time = 201
DILUPBiCG: Solving for Ux, Initial residual = 0.000588805, Final residual = 1.64506e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.00149572, Final residual = 5.55529e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.00907859, Final residual = 3.0994e-06, No Iterations 2
GAMG: Solving for p, Initial residual = 0.00423031, Final residual = 4.10437e-06, No Iterations 19
GAMG: Solving for p, Initial residual = 4.08028e-06, Final residual = 9.36491e-08, No Iterations 20
GAMG: Solving for p, Initial residual = 9.36482e-08, Final residual = 9.36482e-08, No Iterations 0
time step continuity errors : sum local = 7.21952e-10, global = -5.79737e-12, cumulative = -5.79737e-12
DILUPBiCG: Solving for omega, Initial residual = 0.000178982, Final residual = 3.51317e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.00106769, Final residual = 2.67984e-06, No Iterations 2
ExecutionTime = 3.3 s ClockTime = 5 s
As I understand the project should be quasi-two-dimensional. That is two components should be deduced only. Even, if display data of 3 components it is normal for an axis-symmetric of projects, there is one more problem - the component of velocity Uz for quasi-empty dimension most worse to converge. What to do?
Svensson is offline   Reply With Quote
Old   May 16, 2010, 12:40
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Well, I'm not sure what your exact problem is ...
Can you be more specific?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 17, 2010, 04:21
akidess's Avatar
Anton Kidess
It is normal that all three components are still displayed, as the grid is still 3D (just with special cells and boundary conditions). And about Uz: Is it maybe possible that you mixed up X and Z direction during mesh generation (so that Y and Z span your computational plane and X is normal to the side of the wedge)? Did you look at your mesh in paraview to make sure everything is correct?
Old   May 17, 2010, 15:29
Alexander
Can look and prompt why badly to converge quasi-empty component of velocity Uz. Here the project:
http://rapidshare.com/files/38847831...in_tube.tar.gz
Old   May 20, 2010, 12:35
Alexander
Well all right, then can, somebody even to show a correct ready example stationary axial-symmetric flow?
Old   May 21, 2010, 03:46
akidess's Avatar
Anton Kidess
Which solver are you using?
Old   May 21, 2010, 15:15
Alexander
simpleFoam.
Old   May 25, 2010, 04:40
akidess's Avatar
Anton Kidess
Your case doesn't run for me using simpleFoam. I assume you are using 1.6 and I'm still on 1.5, so I can't really help you.
Old   May 27, 2010, 19:13
Alexander
I have installed OpenFoam 1.5. Hardly has altered the project. The problem is considered. But the quasy-empty direction of viscosity Uz is bad to converge.
Here the project:
http://rapidshare.com/files/39231032....5.tar.gz.html
[DesignModeler] axis display disparity of model and triad ram881973 ANSYS Meshing & Geometry 14 November 18, 2020 01:21
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Doubt in unsteady case vijay FLUENT 1 April 24, 2006 11:11
case stops when fuel injection starts Antony Siemens 1 August 7, 2005 13:42
Whatbs best way to create new case jvn OpenFOAM Pre-Processing 2 June 20, 2005 21:19
