Problem with foamJob
Like Tree1Likes
  • 1 Post By truong_nm
Old   May 21, 2010, 01:46
Default Problem with foamJob
KGN
mecbe2002 is on a distinguished road
Hi all,
I am trying to run a problem in parallel using "foamJob" in my laptop which has 2 core. To start with i tried to do a parallelTest, when i execute the command
"foamJob - p -s parallelTest" it shows the following message. So whats the problem.
Parallel processing using OPENMPI with 2 processors
Executing: mpirun -np 2 /home/idea/OpenFOAM/OpenFOAM-1.6/bin/foamExec parallelTest -parallel | tee log
bool Pstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor#0 Foam::error:rintStack(Foam::Ostream&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::Pstream::init(int&, char**&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libPstream.so"
#3 Foam::argList::argList(int&, char**&, bool, bool) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 main in "/home/idea/OpenFOAM/idea-1.6/applications/bin/linux64GccDPOpt/parallelTest"
#5 __libc_start_main in "/lib/libc.so.6"
#6 _start at /build/buildd/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
From function Pstream::init(int& argc, char**& argv)
in file Pstream.C at line 74.
FOAM aborting
[IDeA:02052] *** Process received signal ***
[IDeA:02052] Signal: Aborted (6)
[IDeA:02052] Signal code: (-6)
[IDeA:02052] [ 0] /lib/libc.so.6 [0x7feb58231040]
[IDeA:02052] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7feb58230fb5]
[IDeA:02052] [ 2] /lib/libc.so.6(abort+0x183) [0x7feb58232bc3]
[IDeA:02052] [ 3] /home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x20c) [0x7feb5902e48c]
[IDeA:02052] [ 4] /home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libPstream.so(_ZN4Foam7Pstream4initERiRPPc+0x4ca) [0x7feb57ffacca]
[IDeA:02052] [ 5] /home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbb+0x3138) [0x7feb5903bcf8]
[IDeA:02052] [ 6] parallelTest [0x401994]
[IDeA:02052] [ 7] /lib/libc.so.6(__libc_start_main+0xe6) [0x7feb5821c5a6]
[IDeA:02052] [ 8] parallelTest [0x401859]
[IDeA:02052] *** End of error message ***
Aborted
mecbe2002 is offline   Reply With Quote
Old   May 21, 2010, 08:25
Ngoc-Minh Truong
truong_nm is on a distinguished road
Send a message via MSN to truong_nm
It seems that the error message is not linked to foamJob but simply your case setup.
I would try to run fully manually the computation and see what happens
truong_nm is offline   Reply With Quote
Old   May 21, 2010, 09:13
KGN
I am just exploring parallel running in OpenFOAM. So can you explain in detail what to do?
Old   May 21, 2010, 09:51
Ngoc-Minh Truong
Just change directory to your case folder.
Then:
mpirun -np 2 solverFoam -parallel | tee log
where solverFoam is the solver you use, the same as in controlDict file.
Hope it'll help
atg likes this.
Old   May 21, 2010, 13:34
KGN
Below is the error message, i get. Can you tell what is it?
idea@IDeA:~/OpenFOAM/idea-1.6/run/Practise/forwardStep_1$ mpirun -np 2 rhoSonicFoam | tee log
Missing: program name
Program rhoSonicFoam either does not exist, is not
executable, or is an erroneous argument to mpirun.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
