May 28, 2010, 22:04 |
personal supercomputer
Daniel WEI (老魏)
Rep Power: 21 |
Dear all,
Long time no see. I want to buy a personal supercomputer. I am using a big mac pro now, 8 cores, 32G mem, 10000$, yes, it is really fast. BUT, I am thinking if there's better options. Some say Cray, others say GPU. So, my ultimate questions are: 1. Will OpenFOAM parallel computing works on GPU? Or am I already out-of-date, so, is there anyone of you already using GPU for OpenFOAM, how is it? Anyinfo is appreciated! 2. Based on your experiences, what hardware and computer-company do you suggest me to go? Thanks --------- Note.1 - There is already supercomputer for me to run large cases, I just need a "personal" supercomputer for pre/post processing, or some small CFD cases. Note.2 - 10000$~20000$ would be good Let's talk.
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
May 29, 2010, 13:37 |
Alberto Passalacqua
Rep Power: 36 |
You should give an idea of the size of your cases too, in order to better evaluate the case.
If you use the machine mainly for post-processing, I would not consider GPU-based machines. The GPUs are good to perform the core operations (there is a library for OpenFOAM too: http://vratis.com/speedITblog/ You can contact them, they were very friendly with me.), but for pre/post-processing you still need to rely on traditional CPU's, since the post-processing tools are not designed to work on GPU's. GPU's are very interesting to run cases however, because the power/cost is very convenient. About the company, it depends on what kind of system you choose, and on your personal preference. I personally stay away from Apple (overpriced hardware, technological lock-in, not amazing support). At work we essentially use DELL machines: quality is good, support service is very good as well as the price/quality ratio, hardware support for Linux is excellent. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
May 29, 2010, 14:51 |
#3 | |||
Daniel WEI (老魏)
Rep Power: 21 |
Hi there, thanks
So far, the building experience is not very pleasant on mac for me. I will have a look at dell.
May 29, 2010, 16:20 |
#4 | |||||
Alberto Passalacqua
Rep Power: 36 |
Best,
May 29, 2010, 16:26 |
Daniel WEI (老魏)
Rep Power: 21 |
N series? Can you give me a link?
I checked the Precision workstation, here's their advice (But Win-7 is a necessary option): Model Dell Precision™ T5500/T7500 Workstation Processor Dual Quad Core Intel® Xeon® Processors W5677 3.46GHz Operating System Genuine Windows® XP Professional 64bit Memory 12 GB, 1333MHz, DDR3 SDRAM, ECC Primary Hard Disk 500GB SATA 3.0Gb/s with NCQ and 16MB DataBurst Cache Secondary Hard Disk Graphics Card NVIDIA® Quadro® FX 3800 Display Dual 20", 24"Ultra Sharp or single/dual 27" or 30" UltraSharpTM Any ideas?
May 29, 2010, 17:44 |
#6 | |
Alberto Passalacqua
Rep Power: 36 |
http://premier.dell.com/portal/catal...47&cs=RC956904 If you do not want Windows, simply contact them, they are usually pretty friendly and you can always tell them "no windows, or I don't buy" However, usually, this is not required. Since you are in academia, you probably have right to their academic discount program (check also if your university has deals with them). It is fairly easy to have a system without operating system from them however. Best,
May 29, 2010, 17:55 |
#7 | |
Arjun
Rep Power: 34 |
buy the gpu with meaximim memory possible because that would be your bottle-neck. 2. About post processing, actually gpus are very much suitable for post processing but currently not many programs could exploit this. 3. I am not sure whether openfoam would be converted to gpu based or not. Somebody who knows better might comment on it. 4. About your LES simulations does your mesh move or change with iterations? Edited to add: I just bought corei7 based desktop with gts 240 (1GB memory), so far the functions i have written i can see 10-20 times gains on speed. Not expensive but alright setup. |
May 29, 2010, 21:39 |
#8 | |
Alberto Passalacqua
Rep Power: 36 |
At the moment they seem very interesting if you have a specialized code, to obtain high performance machines at low cost. The story changes when you use commercial applications and/or more general applications, because of the limits of the hardware architecture, and of the fact there isn't many software GPU-enabled out of the box. I find the technology very interesting, but at the moment I'm "watching what happens". I don't think it is convenient to convert codes at this point, if you do not have specific needs. Plus, you tie yourself to a platform, actually to one vendor. Never a great idea, especially if your investment is long term. There is another factor. It seems to me you still need a relatively powerful machine (CPU-based) to work with large cases, since not all the work is done on the GPU. IBM is proposing hybrid solutions for high performance applications, but from what I read (not much), the target doesn't seem to be the workstation market. Best,
May 30, 2010, 08:04 |
#9 | |
Arjun
Rep Power: 34 |
At the moment the biggest hurdle is that codes have to be re-written to make them suitable for gpus. Now this becomes big issue because all the codes - Fluent,starcmm+ (though relatively new), openfoam etc are very large codes and re-writing them to suit gpu is difficult if not impossible. Plus it would take time and people willing to work on it. OpenFOAM as my understanding is very esoteric code (at least is beyond my brain). So chances of modifying it by an outsider are slim. So the core developers would have to do it. I do not think they made any comments about their intensions about it. Personally i do am interested in gpu based navier stokes solver. Next few months i will find out whether for me it would be even feasible to write anything like it. |
May 30, 2010, 11:25 |
#10 |
Don't take a Dell. They are not expensive enough, and you will have difficulties to waste your money.
But don't worry. As Alberto wrote, Dells are just grey. Ask Gucci to design your Personal Supercomputer case, and you can get rid of another 10000$. I thought April Fool's day was too months ago. Anybody else setting a lower limit on his budget and using Macs for CFD? |
May 30, 2010, 12:56 |
#11 |
Alberto Passalacqua
Rep Power: 36 |
Hmm...as first post it looks "interesting". I guess he was stating his maximum budget.
May 30, 2010, 13:09 |
#12 | |
Alberto Passalacqua
Rep Power: 36 |
Best,
May 30, 2010, 15:27 |
#13 | |
Arjun
Rep Power: 34 |
There are two big hurdles 1. GPU programming code has to be c type and it does not allow you object oriented code. But openfoam is object oriented concept. It is however possible to call gpu code from c++ type program for example openfoam so in that way it is possible to call gpu functions from openfoam. 2. Second biggest hurdle is AMG part. Solving amg cycle with gpu is easy but setup could be very difficult. openfoam uses additive corrective multigrid so for them making it parallel is easier i guess. But until someone tries we would never know. Other than these two things i think almost every thing could be written gpu based. So in the end i do agree with you that gpu based acceleration with openfoam is possible. |
May 30, 2010, 18:16 |
#14 | ||
Alberto Passalacqua
Rep Power: 36 |
Best,
May 30, 2010, 18:30 |
#15 |
Daniel WEI (老魏)
Rep Power: 21 |
Hi, thank you.
I would probably use AMG, and FSI research is also on my schedule. I will ask dell. Every time I use mac "magic" mouse, I'm going nuts
Compiling personal BC | fsalvucci | OpenFOAM | 0 | April 27, 2010 17:10 |
Pressure inlet BC for supercomputer | gailms | FLUENT | 0 | November 12, 2009 09:56 |
Problems in personal library compilation | shrina | OpenFOAM | 3 | February 23, 2009 11:12 |
Advertising and Personal Promotion in the CFD-Wiki | Jonas Larsson | CFD-Wiki | 0 | November 20, 2005 19:20 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
