outlet -> inlet how?
Old   June 28, 2010, 09:24
Default outlet -> inlet how?
Benni
egerland is on a distinguished road
I don't know how to set an outlet velocity field result of a previous run as inlet velocity field in my present run.
Can anybody help me
Thanx
egerland is offline   Reply With Quote
Old   June 28, 2010, 09:35
NorbertB is on a distinguished road
You can try that (in your system file):
startFrom lastTime;
NorbertB is offline   Reply With Quote
Old   June 28, 2010, 10:15
Benni
Hi Norbert,
I have a case, in which my inlet (O/U) of the boundaryField is fixedValue, uniform (10 0 0).
my outlet is set to zeroGradient.
In a next case, I want to take the results of the outlet velocity field and set them as the boundary field of the inlet for the new case. Instead of fixedValue, I want to use the results of the old case.
Old   June 28, 2010, 10:58
Martin
MartinB will become famous soon enough
Hi Benni,
have a look at the mapFields utility: in the mapFieldsDict you can use the patchMap function.
http://www.openfoam.com/docs/user/mapFields.php
In your case the entry for patchMap might be:
patchMap (outlet inlet);
Preparations:
- define the appropriate mapFieldsDict in your second simulations "system" directory.
- use boundary condition fixedVelocity for the inlet of your second simulation with a dummy value of (0 0 0) initialized.
The command sequence is something like (replace the paths and the 1000):
cd path_to_second_simulation
mapFields path_to_first_simulation -sourceTime 1000
Check with paraview before starting the second simulation.
Martin
MartinB is offline   Reply With Quote
Old   June 29, 2010, 05:28
Benni
Hi Martin,
thanx for your help.
I tried the second simulation with mapFieldsDict. The Field in paraview is o.k.
But I get the following error:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type fixedVelocity)
on patch inlet of field U in file "/home/eggert/OpenFOAM/eggert-1.6/run/cube_cyclic/0/U"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 782.
FOAM exiting
The other point is: I think mapFields is perhaps not the right tool for what I want to do. I have a 2-D case with inlet on the left and outlet on the right. In the middle of the mesh I have a box, which stands for a wall in a 3D case.
For every simulation step the velocity Field at the outlet would be the inlet for the next simulation step. This means, that this simulation will give the same solution as a simulation with many boxes in a row.
My problem is to generate the inlet velocity field for every step of the simulation.
Old   June 29, 2010, 10:47
Martin
Hi Benni,
I assume that the cyclic boundary condition is the BC you are looking for.
Since I don't have experience with it, you may have a look at these threads:
http://www.cfd-online.com/Forums/ope...implefoam.html
http://www.cfd-online.com/Forums/ope...condition.html
This example in the OpenFOAMs tutorial directories might help, too:
tutorials/incompressible/channelFoam/channel395
Good luck
Martin
Old   July 26, 2017, 03:44
Question i also have same problem please help
Amar
Amar_CFD is on a distinguished road
hi
I am also trying to simulate the same case. I have one pipe and valve as a first geometry. i want to give outlet velocity of the first case as inlet velocity distribution for second case which is simple pipe.
1)I tried using mapFields as follows
in second case directory
mapFields -path_to_first_case -sourceRegioin -outlet -targetRegion inlet
i also modified mapFieldDict in second_case/system as
patchMap (outlet inlet )
its showing the error
-FOAM FATAL ERROR
cannot find file "points" in directory first_case/outlet in times "latest_time_value down to constant.
please help.
Amar_CFD is offline   Reply With Quote
outlet -> inlet how? egerland OpenFOAM Pre-Processing 0 June 22, 2010 13:11
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
Outlet -> Inlet How? lego CFX 2 August 13, 2002 12:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
