Problem with mpirun with OpenFOAM
Like Tree6Likes
  • 1 Post By jiejie
  • 5 Post By thekay
Old   July 7, 2010, 05:19
Default Problem with mpirun with OpenFOAM
Jie
jiejie is on a distinguished road
Recently I am having a strange problem with mpirun in OpenFOAM 1.6. I am running 3D LES of flow over a cylinder. I have 17 nodes (16 cells) in the spanwise direction (z-direction).
When I did a very coarse mesh (7500 cells per plane) in the xy plane, i can decompose the domain into 8 portions in the z-direction and run without any problem.
When I did fine mesh (120,000 cells per plane) in the xy plane, I decompose the domain into 8 portions in the z-direction. After I executed the mpirun -np 8 pisoFoam -parallel, it complains the followings:
Create time
Create mesh for time = 0
[shuang:8030] *** An error occurred in MPI_Bsend
[shuang:8030] *** on communicator MPI_COMM_WORLD
[shuang:8030] *** MPI_ERR_BUFFER: invalid buffer pointer
[shuang:8030] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
mpirun has exited due to process rank 0 with PID 8030 on
node shuang exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[shuang:08029] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[shuang:08029] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Then I decompose it into 2 portions along each the x, y (2 2 2 ) direction. It runs without this problem. If I wanna run the simulaiton with 8 portions along z-direction, what should I fix?
Does anyone encounter such a problem as well?
wht likes this.
jiejie is offline   Reply With Quote
Old   July 7, 2010, 05:37
Sebastian Bartscher
sbar is on a distinguished road
I have the same problem. I'm running a simpleFoam simulation on an 8 core Workstation. I decomposed the mesh in 8 parts in x direction. The error doesn't appear every time. I read in another forum that there was/is a bug in openMpi that should be fixed. something about restarting checkpoints.
would be great if someone could help.
sbar is offline   Reply With Quote
Old   July 7, 2010, 09:17
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
You need to raise the mpi buffer size. This can be done by running something like:
MPI_BUFFER_SIZE=150000000
. Normally you'd like to put it in your settings file so you don't have to run it each time.
thekay is offline   Reply With Quote
Old   July 7, 2010, 19:30
Jie
Thanks thekay
it works well after I increase the buffer size.
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 02:00
OpenFOAM 1.7.0 installation problem stevek OpenFOAM 14 December 1, 2010 15:30
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 04:35
Problem on Installing OpenFOAM 1.6 on Fedora 11 lzgwhy OpenFOAM Installation 1 August 25, 2009 11:02
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
