slip ratio between gas/liquid
Old   August 17, 2010, 12:11
Default slip ratio between gas/liquid
Robert Langner
Robat is on a distinguished road
Hi foamers!
I have a two phase model in LesInterFoam, where I need to to know the velocity for each phase (of course besides the pressure loss).
My idea was to create an additional volume flux field for one single phase like "phiLiq" via gamma(or alpha) field.
I've made a "elbow-case" like pipe (a gas flow with liquid injection) to test my idea, but it not delivered me a slip ratio.
Does anybody know a good strategy or at least could give me a hint from which value I could get the information to calculate the gas slip ?
bests,
Robert
P.S.: This might be interesting for evaporation models like interDymFoam.
Robat is offline   Reply With Quote
Old   August 17, 2010, 16:54
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Hi Robert,
interFoam is based upon the homogeneous mixture assumption. In consequence you have to live with only a mixture velocity, which in turn demands for a high resolution for both the interfacial morphology (e.g. curvature) and boundary layer.
To evaluate a reasonable local slip velocity (i.e. for under-resolved boundary layers) would need a rewrite of the solver + theoretical work considering phase interaction and interchange...
As a start you might consider the work of M. W๖rner and W. Sabisch, references of whom can be found here: http://bibliothek.fzk.de/zb/berichte/FZKA6889.pdf
In case you have any further questions let me know... I am on another approach considering an interfacial flow solver employing two momentum balances, thus inherently enabling for a interfacial phase slip.
best regards,
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   August 18, 2010, 05:41
Robert Langner
Thanks for your quick reply.
I go to check the work of these people.
I'll keep you informed, if I find a good solution.
bests,
Robert
Old   August 18, 2010, 09:05
Holger Marschall
Sure, you are welcome...
Look out for VA-VOF as this method accounts for a phase slip (momentum drift flux term).
best,
Holger Marschall
interfoam, slip ratio
Slip BC not working properly lfbarcelo OpenFOAM 3 July 15, 2010 09:53
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Low-Pressure Boundary Slip AlexA FLUENT 1 January 5, 2007 21:30
Free slip and no slip. Yung Fidelity CFD 2 August 16, 2006 09:24
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
