Ovidiu Michiu
Rep Power: 16 ![]() |
I'm trying to do my first case in OF. I converted a mesh from fluent, an airfoil 2D, compressible flow with M=0.8, Spalart-Allmaras imposed and a Courant Numner=200 in fluent. I adapt an compressible case from tutorials of OF, /sonicFoam/RAS/naca. I can see the mesh without any problems, but I don't know how can I calculate the time step, delta t from /system/controlDict. The second problem regards the thermophysicalProperties definition. I read the tutorial but when i started to write my thermophysicalPropoperties i got stuck; I have sutherland law imposed and perfect gas; how can i calculate all the coefficients to have a good thermoProp correct? Thk, Best Regards, Ovidiu |
Rep Power: 18 ![]() |
The courant number is defined like this:
C = (U * delta t) / delta x with U = velocity of the liquid/ moving wall what ever delta t you want to calculate and delta x = domain length [m] / Number of Elements in x direction for more details see here: http://www.openfoam.com/docs/user/cavity.php chapter 2.1.1.4 Control It happens to be the first tutorial..... |
Ovidiu Michiu
thk colinB,
i check the tutorial before posting the thread. the problem is that i don't know the cell size, delta x. i receive the mesh from fluent, i didn't do the mesh and i don't have fluent install on my pc to see the cell mesh. Best, Ovidiu |
Anton Kidess
Rep Power: 30 ![]() |
After conversion you can run checkMesh, and then get information about cell volumes. For a rough estimate of the Courant number you can take the third root of the cell volume.
#5 | |
Sabin Ceuca
you can actually plot the cell Volumes using the variable mesh.V() and then compute the dx you like best ![]() Ciao, Sabin |
RMS Courant Number vs MAX Courant Number | zoozoozoo | Main CFD Forum | 3 | June 12, 2012 13:44 |
Problems with Courant number (LaunderGibsonTurbulence Model) | sven | OpenFOAM | 3 | August 10, 2009 03:12 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
pls help fluctuating residuals due to courant no | sagar | CFX | 3 | March 28, 2006 01:10 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
