max courant/courant...velocity spikes?
Old   September 1, 2010, 12:55
Default max courant/courant...velocity spikes?
Matt James
mdjames is on a distinguished road
I'm running a turbulent half-channel flow (dynSmag). I'm wondering why the max courant number is being reported in the neighborhood of 10-12 while the mean courant is around 0.3, where i calculated it based on expected mean flow.
Where might these wild velocity fluctuations be coming from?
Thanks very much for any help!
mdjames is offline   Reply With Quote
Old   September 17, 2010, 00:59
Alberto Passalacqua
Have you very refined cells somewhere in your domain?
Alberto Passalacqua
Old   September 17, 2010, 13:08
Matt James
Ah, yes. I have some near wall refinement but only in the wall normal direction. Eddy generation and therefore v and w velocities occurring I suppose?
Old   September 21, 2010, 15:06
Steven van Haren
stevenvanharen is on a distinguished road
Have the same "problem" in my channel flow LES/DNS.
If you are interested you can use the Co utility to determine where the high Courant number appears.
stevenvanharen is offline   Reply With Quote
Old   September 24, 2010, 03:32
maysmech's Avatar
maysmech is on a distinguished road
i have two questions.
Originally Posted by mdjames View Post
How can you find mean courant number? because in terminal min and max courant number is displaying only.
Is it possible to tell more about Co utility?
maysmech is offline   Reply With Quote
Old   September 24, 2010, 04:20
Steven van Haren
Which solver are u using? I get mean and max Co in my terminal window using channelFoam/channelOodles.
Co utility should be in your openfoam folder. Just use Co -help to see how it works.
Old   September 24, 2010, 05:44
maysmech's Avatar
i use pisoFoam. i want solve a rearward facing step with RAS and LES. my problem is i don't know how much can courant be large in solving process. do you know about it?
Old   September 24, 2010, 06:26
Steven van Haren
RAS, no idea
LES, max CFL ~ 0.5
Old   September 24, 2010, 09:13
maysmech's Avatar
RAS, no idea
LES, max CFL ~ 0.5
Thanks for your reply.
is it a law for LES or it depends on cases? also please tell your reference.
Best regards.
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
How to calculate Velocity? Kali Sanjay Phoenics 1 May 1, 2006 13:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
