Steady state Multi species non-reactive model
Old   September 6, 2010, 08:36
Default Steady state Multi species non-reactive model
Hrushikesh Khadamkar
Hrushi is on a distinguished road
hi,
I am new to OpenFOAM. I want to develop steady state multi species non reactive model. How to go about it?
Do I need to modify the simpleFoam code to introduce the species equation? If yes, how to do it? Correct me, if I am wrong.
Is there any otherway to do this?
Hrushikesh
Hrushi is offline   Reply With Quote
Old   September 7, 2010, 06:29
Markus Rehm
markusrehm is on a distinguished road
I guess it would be easier the way round. Start with reactingFoam and switch off the chemistry source terms. Then you can make it a steady state solver. Maybe buoyantSimpleFoam is also a good start because it already deals with temperature.
Regards Markus.
Originally Posted by Hrushi View Post
hi,
Hrushikesh
markusrehm is offline   Reply With Quote
Old   September 7, 2010, 06:45
Hi Markus,
I will try your suggestions. I will get back to you if I face any difficulty. Have a good day!!!
Thanks
Hrushikesh
Regards Markus.
Old   August 11, 2011, 14:18
Kia
karasa03 is on a distinguished road
Hi Hrushi,
Were you able to implement a steady state solver steady state multi species non reactive model. I am working on the same thing and was using the Particle-tracking LTSReactingParcelFoam with everything turned off, but my pressure was blowing up. I also used porousExplicitSourceReactingParcelFoam transient solver, but my rho and temperature was not changing. I was thinking if a combustion solver will be better with the reaction turned off.
Regards Kiyya
karasa03 is offline   Reply With Quote
Old   June 5, 2014, 13:00
Default reactingFoam to steadyState
James
ni-openfoam-user is on a distinguished road
Hi Hrushi,
As per the previous question from Kiyya,
Where you able to development and implement reactingFoam as a steady state solver?
In addition to switching off chemistry (chemistryProperties) and combustion (combustionProperties) what other steps must be taken in order to adapt the reactingFoam solver into a steadyState solver?
Kind regards,
James
ni-openfoam-user is offline   Reply With Quote
model, multispecies, non-reactive, steadty state
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Appropriate model for turbulent, steady state pipe elbow flow milos OpenFOAM Running, Solving & CFD 4 July 9, 2009 02:24
regarding steady state discrete phase calculations hajszan_gyula FLUENT 1 February 28, 2006 01:32
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
