Defining B.C. --> velocity profile
Old   September 7, 2010, 12:52
Question Defining B.C. --> velocity profile
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
I need to define Driver and Seegmiller velocity inlet profile for backward facing step.
How can i write it in 0/U flie?
maysmech is offline   Reply With Quote
Old   September 7, 2010, 21:21
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Maysmech, groovBC is your friend:
http://openfoamwiki.net/index.php/Contrib_groovyBC
but you can write the boundary condition by hand using octave. You have to specify a nonuniform field with one vector per patch face in the boundaryField section of 0/U. In this case you have to know the face center coordinates for each cell and the faces indexes. Faces in the patch are ordered by face indexes, so you have to write the boundary values in the same order.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   September 8, 2010, 02:09
maysmech's Avatar
Regards.
Thanks for your reply.
your suggestions seems hard labor. is it other way to define B.C?
Old   September 8, 2010, 08:05
Maysmech, there isn't a BC in FOAM that allows to load a profile directly putting the expression, this is the main objective of groovyBC. Because this tools is not included in original FOAM suite, you have to compile it. The other option is valid in all cases too, but more often used in simple ones.
Good luck.
Research Scientist
Old   September 8, 2010, 11:13
maysmech's Avatar
Good luck.
Thanks Santiago,
if i want use 2nd option, how should i use it?
i have less than 10 data for inlet. and i can expand it for inlet grids which has more than 200 grid with different sizes in excel software.
where can i define inlet B.C. only for inlet and what should be its format? other B.C. have standard types(fixed value, symmetry and ...)
Best,
Old   September 8, 2010, 16:41
Maysmech, the only difficult thing with the second option is to know of index of patch faces. If the patch is meshed with an structured mesh, it probably be by row or column. For example if you have 20 faces in five rows of 4 faces each one, probably the numbering is 0-3 in the first row, etc.
This difficult appears due mesh info in /constant/polymesh doesn't include cells centers, this info is obtained on the fly at running time. Obviously you can obtain this info writing a simple tool.
Supposing you would have only one patch with 2 faces, you have to fill the boundaryField section like this:
boundaryField
inlet
type fixedValue;
value nonuniform List<vector>
2
(0 0 1)
(0 0 0.95)
The velocity vector have to be calculated from coordinates and velocity profile function.
Regards.
Research Scientist
Old   September 10, 2010, 16:04
Thumbs up
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
Hi maysmech and santigo
use command writeCellcenters then use Cycellcenters then give velocity profile as santigo explained
this will fix your problem. its bit lengthy process but an easier way.
Regards
Ambilpur Kiran
kiran is offline   Reply With Quote
Old   September 10, 2010, 16:18
kiran, I didn't know writeCellCentres command, it's good info. Strictly you need to know the faces center coordinates to calculate values in a patch. Is there a commando to do so? What is the other command you mentioned (Cycellcenters)?
Regards.
Research Scientist
Old   September 10, 2010, 16:29
Thumbs up
kiran Ambilpur
Hi santiago
writeCellCenters command will generate three files namely Cx cellcenters, Cycellcenters and Czcellcenters in 0 directory.
so in order to give velocity profile u need only Y cell centers so use Cycellcenters file to give the velocity vectors.
so the problem is solved
Regards
Ambilpur Kiran
Old   September 10, 2010, 16:40
maysmech's Avatar
Dear Kiran,
thank you very much for your help,
The command you told is very useful to know about order, position and coordination of needed cells.
i want to define inlet boundary conditions so i think i need boundary face coordinates and finding them becomes hard when grids have different sizes.
Is it any idea to find them?
Old   September 10, 2010, 16:42
Kiran
Originally Posted by kiran View Post
Hi santiago
Aha, I tried the tool and it prints face cell centroids coordinates too. This is the info needed for B.C.
Thanx.
Research Scientist
Old   September 10, 2010, 16:52
maysmech's Avatar
Thanx.
You mean it prints cell center coordinates for internal field and face center coordinate for boundaries?
Old   September 10, 2010, 17:00
Yes, I tried with an example, and it did it.
Regards.
Research Scientist
Old   September 12, 2010, 13:18
Lightbulb
  #14
kiran Ambilpur
hi maysmech
use that command then it generates three files as i explained earlier.
Open CyCellcenters file the scroll down u will find the cellcenters in the inlet, copy those to excel sheet.
These are your y distance in the boundary layer equation (you can choose any boundary layer equation accordind to your requirement). (in fact these are the Y locations from the boundary eg from wall )
so simply write the formula(boundary layer equation) in the another column to calculate velocity at that cellcenter.
The point where your velocity increases more than free stream or given inlet condition stop there and give the U~=(0.99u).
similarly take the cells from bottom reverse the formula then do it(if mesh is same then take same number of cells from bottom if not do as i explained).
this is what I can explain you at Maximum level.
hope you will try to do this and solve your problem.
Regards & Best of Luck
Ambilpur Kiran
Old   September 12, 2010, 21:06
I mostly agree, but the cy values bust be taken from inlet boundary, and the results in boundary of U too.
Regards.
Research Scientist
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 17, 2009 23:36
Velocity Profile Jeff FLUENT 1 November 24, 2008 08:21
problem with velocity inlet profile file Duncan FLUENT 3 November 21, 2005 07:28
