powerLaw
Old   September 30, 2010, 05:26
Default powerLaw
Leo Pratama Gani
lgani is on a distinguished road
Hi everyone.
Thanks in advance for the help.
I am trying to simulate this power law type fluid behaviour in a pipe flow.
However, I am stuck in the transportproperties file where I have to set the properties of the fluid. I found one thread that says
transportModel powerLaw;
nu nu [0 2 -1 0 0 0 0] 1e-05;
powerLawCoeffs
k k [0 2 -1 0 0 0 0] 2500;
n n [0 0 0 0 0 0 0] 0.4;
nuMin nuMin [0 2 -1 0 0 0 0] 0;
nuMax nuMax [0 2 -1 0 0 0 0] 100;
I am not sure though how to change my unit of k which is in Pa s^1/n to this unit required by openfoam.
Any idea or help with powerLaw fluid flow ?
Cheers
lgani is offline   Reply With Quote
Old   September 30, 2010, 21:04
Lachlan Graham
Locky3827 is on a distinguished road
Hi Leo,
OpenFoam uses a kinematic viscosity so you need to divide the k value by the density of your fluid. You will also need to check your pressure results as the pressure is also divided by the density.
You will also need to check the shear rate used by OpenFoam, if you search the forum there is a thread about that as well (don't know how to put the link in from here).
With laminar pipe flow of a power loaw fluid you can check the results against an analytical result.
Let us know how you get on, there only seems to be a few people doing non-Newtonian flow.
Regards,
Locky
Locky3827 is offline   Reply With Quote
Old   October 1, 2010, 02:26
Primoz Ternik
ternik is on a distinguished road
your units (normalized with the pressure) for the Power law coefficients are O.K.! It is true that correct unit for the Power law "consistency coefficient" k should be Pa s^(1/n), but I am using the same units and it works!
More important - please note, that the implementation of the shear rate (that is IInd invariant of symmetrical rate of deformation tensor) is not correct (at least in OF-1.5) and it should be:
return sqrt(2.0)*mag(symm(fvc::grad(U_)))
Hope this helps you!
Cheers,
Primoz
Originally Posted by lgani View Post
Hi everyone.
powerLawCoeffs
Cheers
ternik is offline   Reply With Quote
Old   August 6, 2012, 14:20
anonymous
Mahyar Javidi is on a distinguished road
Hi
Could anybody tell me when we implement power-law coefficients what is the nu in the line before that? What kind of value I have to implement for it while I am using the power-law coefficients
Regards
Mahyar Javidi is offline   Reply With Quote
Old   August 6, 2012, 14:25
Nima Samkhaniani
nimasam is on a distinguished road
hi mahyar
a newbie question :P
when you choose powerlaw, that mentioned nu is trivial, and the program reads the parameters you defined in powerLawCoeffs
P.S: that nu is for Newtonian transport model
nimasam is offline   Reply With Quote
Old   August 6, 2012, 16:46
anonymous
Thanks Nima
Creating a new OpenFOAM case Wesley OpenFOAM 26 May 3, 2011 12:26
Powerlaw for porous medium Shankar FLUENT 0 August 27, 2002 12:54
