Rotor - stator how to create mesh?
Old   October 6, 2010, 14:43
Smile Rotor - stator how to create mesh?
David
davidmd is on a distinguished road
Send a message via ICQ to davidmd
In this thread I used the boundary condition rotatingWall for bottom of cylinder filled with liquid. But now my task a little harder. I need to create an edges at the bottom of the cylinder. Like on the picture.
In this case, the bottom together with the edges should rotate. Can someone help or give links to related tutorial?
As I understand, I have to use a rotor and a stator patches. How to do it? Or may have another way?
I apologize for my silly drawings and terrible English
davidmd
davidmd is offline   Reply With Quote
Old   October 7, 2010, 02:38
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hi David,
in this case you should use MRFsimpleFoam, since you consider the air between the "blades" rotating as the rotor. Thus, starting with the tutorial of this solver can be a good idea.
Cheers,
mad
maddalena is offline   Reply With Quote
Old   October 15, 2010, 15:30
David
[QUOTE=maddalena;278205]Hi David,
As I understand, I have to use a rotor and a stator patches. How to do it? Or may have another way?/QUOTE]in this case you should use MRFsimpleFoam, since you consider the air between the "blades" rotating as the rotor. Thus, starting with the tutorial of this solver can be a good idea.
Cheers,
mad
Hi maddalena! Once again thank you for helpful advice! I can not even imagine what I would do without you! It seems that it works, but the problem is solved with the turbulence, while I need laminar. Is there any way to turn off turbulence for this solver? I mean MRFSimpleFoam.
Best wishes!
davidmd
Old   October 16, 2010, 00:40
paka is on a distinguished road
I'm not sure if it possible in OpenFOAM, but I would just assign all the members to the same patch and assign rotation. Just a first idea which came to my mind.
paka is offline   Reply With Quote
Old   October 16, 2010, 05:52
FG_HSRM is on a distinguished road
[QUOTE=davidmd;279416]
Best wishes!
Hi David
Yes there is, just go in to the RasProperties file and switch it off.
FG_HSRM is offline   Reply With Quote
Old   October 25, 2010, 07:26
Sarah Köhler
sarahk is on a distinguished road
Hey,
do you know how the Coriolis Force is implemented in MRFSimpleFoam or in OpenFoam in general?
I cant find the file.
the equations i got from OpenFoam Wiki include the Coriolis and Zentripetal force, but in the MRFSimpleFoam.C file it is written that they just add the Coriolis term.
Thanks
Sarah
sarahk is offline   Reply With Quote
Old   October 25, 2010, 08:12
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Sarah,
I thinks its a little hidden in the MRFZone.C file.
Within the member function there are two overloaded addCoriolis functions (in the internet doxygen it's line 294
( void Foam::MRFZone::addCoriolis(fvVectorMatrix& UEqn) const)
and 315
( void Foam::MRFZone::addCoriolis (const volScalarField& rho, fvVectorMatrix& UEqn) const).
If you click on the Foam::MRFZone::addCoriolis it is linked to the doxygen.
Hope this helps
Kathrin
kathrin_kissling is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
