lift and drag coefficient
Like Tree4Likes
Old   October 15, 2010, 06:42
Default lift and drag coefficient
Girolamo
lift86 is on a distinguished road
Hello, I am new to open foam, I'm trying the tutorial 2d airfoil (simplefoam incompressible). I can not see the values of lift and drag coefficients. I have to put in the contol dict lines you suggested, but I get nothing. How can I do? thanks
functions
forces
type forces;
functionObjectLibs ( "libforces.so" ); // lib to load
outputControl timeStep;
outputInterval 1;
patches
wall // change to your patch name
// name of fields
pName p;
UName U;
log true; // dump to file
rhoInf 1025;
CofR ( 0 0 0 );
forcesCoeffs
type forceCoeffs;
outputInterval 1;
patches
// name of fields
pName p;
UName U;
rhoInf 1025;
CofR ( 0 0 0 );
liftDir ( 0 1 0 );
dragDir ( 1 0 0 );
pitchAxis ( 0 0 0 );
magUInf 7.30;
lRef 0.305;
Aref 0.001525;
lift86 is offline   Reply With Quote
Old   October 18, 2010, 07:47
Alejandro
velezisaza is on a distinguished road
The script looks fine, are you placing it in the controlDict? I also had some troubles running it in openfoam 1.7. In 1.6 however it works perfectly. Try it!
If you want moment coefficient you have to change the pitch axis to 0 0 1
Rajib and AndrejCFD like this.
velezisaza is offline   Reply With Quote
Old   October 21, 2010, 04:02
Vesselin Krastev
vkrastev is on a distinguished road
Have you changed "wall" with the name of the patch (or patches) composing the airfoil?
vkrastev is offline   Reply With Quote
Old   October 21, 2010, 05:06
Girolamo
I use open foam nn 1.7.1 but nothing happens, even if the procedure is correct. In your opinion, should I download the library "libforces?
Old   October 22, 2010, 08:46
Alejandro
Check if you have the libforces.so library, its shoulf be in OpenFoam1.7.1/lib/linux64GccDPOpt/libforces.so
My problem with openfoam 1.7.1 is that it says that it cannot locate p and U, so it deactivates "forces". But the same script in 1.6 works perfectly fine. Vesselin, have you tried it yourself in 1.7.0 or 1.7.1?
Old   October 22, 2010, 09:50
Vesselin Krastev
Unfortunately I do not have much experience with the 1.7.x versions, but I have noticed that there are several different particulars between those versions and the 1.6 one: for instance, the interFoam solver of the latest versions uses a different definition of the pressure, and so on...However, the script I use to calculate the force coefficients (in the 1.6 version) is slightly different from the one posted above: don't know if it makes some difference, but maybe you could try it in the 1.7.x one
Regards
V.
ps-the name of the function is not significant: it simply determines the name of the directory in which the forceCoeffs data will be stored
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 5000;
deltaT 1;
writeControl runTime;
writeInterval 500;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
functions
totalDrag
// rhoInf - reference density
// CofR - Centre of rotation
// dragDir - Direction of drag coefficient
// liftDir - Direction of lift coefficient
// pitchAxis - Pitching moment axis
// magUinf - free stream velocity magnitude
// lRef - reference length
// Aref - reference area
type forceCoeffs;
functionObjectLibs ("libforces.so");
patches ( body );
rhoName rhoInf;
rhoInf 1.184;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 40;
lRef 0.288;
Aref 0.0561;
outputInterval 50;
mm.abdollahzadeh likes this.
Old   October 25, 2010, 05:56
Girolamo
Hello. I am studying the case of a cylinder.
these are the files that I put:
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
startTime 0;
stopAt endTime;
endTime 500;
deltaT 1;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
functions
forces
type forces;
outputInterval 1;
patches
// name of fields
pName p;
UName U;
rhoInf 1025;
CofR ( 0 0 0 );
forcesCoeffs
type forceCoeffs;
outputInterval 1;
patches
// name of fields
pName p;
UName U;
rhoInf 1025;
CofR ( 0 0 0 );
liftDir ( 0 1 0 );
dragDir ( 1 0 0 );
magUInf 7.30;
lRef 0.305;
Aref 0.001525;
// Definition of terms:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
inlet
type freestreamPressure;
outlet
wall
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (30 0 0);
boundaryField
inlet
type freestream;
freestreamValue uniform (30 0 0);
outlet
type freestream;
wall
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
how do I get the CD and Cp Cl??
Old   October 25, 2010, 06:12
Girolamo
i have also this error in the terminal(when i start the iteraction):
--> FOAM Warning :
From function void forces::read(const dictionary& dict)
in file forces/forces.C at line 277
Could not find U, p or rho in database.
De-activating forces.
Old   October 26, 2010, 07:40
Alejandro
I had the same error but now its working fine. As Vesselin used, I removed the pName and uName inputs, and added the rhoName rhoInf.
It works perfect now with 1.7.1
Girolarno, I hope it works for you as well
Old   October 26, 2010, 08:12
Girolamo
Thank you so much you were very kind ...... but you may be able to plot the pressure coefficient on the wall? How do you do for plotting?
Old   October 26, 2010, 09:49
Alejandro
Pressure coefficient is another story. For that you use the sampling utility. You need the following file in your system directory: sampleDict.
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location system;
object sampleDict;
// Set output format : choice of
// xmgr
// jplot
// gnuplot
// raw
setFormat raw;
// Surface output format. Choice of
// null : suppress output
// foamFile : separate points, faces and values file
// dx : DX scalar or vector format
// vtk : VTK ascii format
// raw : x y z value format for use with e.g. gnuplot 'splot'.
// Note:
// other formats such as obj, stl, etc can also be written (by proxy)
// but without any values!
surfaceFormat raw;
// interpolationScheme. choice of
// cell : use cell-centre value only; constant over cells (default)
// cellPoint : use cell-centre and vertex values
// cellPointFace : use cell-centre, vertex and face values.
// 1] vertex values determined from neighbouring cell-centre values
// 2] face values determined using the current face interpolation scheme
// for the field (linear, gamma, etc.)
interpolationScheme cellPoint;
// Fields to sample.
fields
p
// Set sampling definition: choice of
// uniform evenly distributed points on line
// face one point per face intersection
// midPoint one point per cell, inbetween two face intersections
// midPointAndFace combination of face and midPoint
// curve specified points, not nessecary on line, uses
// tracking
// cloud specified points, uses findCell
// axis: how to write point coordinate. Choice of
// - x/y/z: x/y/z coordinate only
// - xyz: three columns
// (probably does not make sense for anything but raw)
// - distance: distance from start of sampling line (if uses line) or
// distance from first specified sampling point
// type specific:
// uniform, face, midPoint, midPointAndFace : start and end coordinate
// uniform: extra number of sampling points
// curve, cloud: list of coordinates
sets
// Surface sampling definition: choice of
// plane : values on plane defined by point, normal.
// patch : values on patch.
// 1] patches are not triangulated by default
// 2] planes are always triangulated
// 3] iso-surfaces are always triangulated
surfaces
airfoil
type patch; // always triangulated
patchName Airfoil;
slat
type patch;
patchName Slat;
I got this from a tutorial, I don't remember which one, and its also explained in the user guide.
After running your simulation you run the sample utility. After that you can use matlab or excel to calculate the Cp.
Good luck!
Old   December 18, 2010, 16:22
Maryam Mousazadeh
anijdon is on a distinguished road
Hello Alejandro,
excuse me, I have an basically question because I'm not sure.
Is it enough that add mentioned lines to controlDict for calculating drag/lift coefficient in a steady state simulation? or we should copy other specific directories in our own case and use specific command during simulate?
in this way can we use sampleDict to plot these coefficients?
thanks
anijdon is offline   Reply With Quote
Old   December 19, 2010, 04:21
Alejandro
To calculate the drag and lift coefficient, the lines inside the controlDict are enough. After running the simulation you should have a directory in your case directory called forceCoeffs or whatever name you give to your function in your controlDict. after that, what I did was import the data in matlab and then plot it, but that depends on you.
This is are the lines I added. I also include the field average in case you need it at a later stage.
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
startFrom startTime;
startTime 10000;
stopAt endTime;
endTime 20000;
deltaT 1;
writeInterval 2000;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
functions
forceCoeffs_combi
type forceCoeffs;
enabled true;
outputInterval 1;
patches
Slat
Airfoil
rhoName rhoInf;
log true;
rhoInf 1.225;
CofR (0 0 0);
liftDir (-0.309 0.95106 0);
dragDir (0.95106 0.309 0);
pitchAxis (0 0 1);
magUInf 51;
lRef 0.3;
Aref 0.0081;
forceCoeffs_airfoil
type forces;
enabled false;
outputInterval 1;
patches
Airfoil
log true;
rhoInf 1.225;
CofR (0 0 0);
pitchAxis (0 0 1);
magUInf 51;
lRef 0.3;
Aref 0.0075;
forceCoeffs_slat
type forces;
enabled false;
outputInterval 1;
patches
Slat
pName p;
UName U;
log true;
rhoInf 1.225;
CofR (0 0 0);
pitchAxis (0 0 1);
magUInf 51;
lRef 0.3;
Aref 0.0001566;
fieldAverage1
type fieldAverage;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputInterval 2000;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
Old   December 19, 2010, 10:38
Maryam Mousazadeh
I thank you for your helping, but I don't know what's the usage of field average and why we should obtain it?
thanks
Old   December 21, 2010, 04:20
Default forces.dat information
  #15
inginer's Avatar
Ovidiu Michiu
inginer is on a distinguished road
i have a 2d airfoil and i used simpleFoam to run the case; i have the coefficient lift, drag and momentum. also, i have the forces calculated.
my question is: when i open the forces.dat (were are the forces) file i have on the first line time, forces(pressure, viscous) momentum(pressure, viscous)
and the second line i have 13 colones of numbers, corresponding to time, forces and momentum. but, why do i have 12(+1 the time) and not 9(+1 the time)?
best,
Ovidiu
inginer is offline   Reply With Quote
Old   December 22, 2010, 08:34
David Boger
boger is on a distinguished road
Based on the first line, the 12 columns are the pressure and viscous component of the force, and the pressure and viscous component of the moment. Since each of these 4 items is a vector, you have 12 columns. Plus time.
David A. Boger
boger is offline   Reply With Quote
Old   January 7, 2011, 10:49
The True
Eren10 is on a distinguished road
I have put the required function in the controlDict file, but after running there happens nothing. I was just testing an airfoil with icoFoam app. I even copied the functions from an tutorial.
functions
forces
type forceCoeffs;
outputInterval 1;
patches
AirFoil // this consists of the lower and the upper camber, defined as a wall in the BC
pName p;
UName U;
log true;
rhoInf 1;
CofR ( 0 0 0 );
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis ( 0 0 1 );
magUInf 25;
lRef 1;
Aref 1;
Eren10 is offline   Reply With Quote
Old   January 7, 2011, 10:54
David Boger
What if you use parentheses rather than braces for the list of functions and a semicolon at the end?
functions
  forces
David A. Boger
Old   January 7, 2011, 11:00
The True
no still doesn't do anything.
Old   January 7, 2011, 11:06
David Boger
I just pasted your entry (with the modifications I already mentioned) into my controlDict and I got the desired output in forces/0/forceCoeffs.dat.
David A. Boger
lift & drag coefficient on airfoil n. natik FLUENT 8 March 31, 2015 19:02
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 10:52
Drag coefficient & Lift coefficient?? mehrdadeng CFX 15 December 9, 2009 21:49
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
