Problem regarding solution under-relaxation
Old   October 20, 2010, 11:49
Default Problem regarding solution under-relaxation
Edy
Edy is on a distinguished road
Hi Foamers,
I am modeling subcooled boiling and condensation using a two phase Euler-Euler approach. So i solve mass, momentum and energy conservation equations for both phases.
I checked several times my model and i am pretty sure that it is physically correct. I mean, the equations i implemented make sense. However my simulation (a simple 2D channel) crashed very quickly...
I think this is due to numerical calculation reasons, so i used relaxation factors, in order to improve the stability of the computation. Here are the solvers and relaxation factors i set:
solvers
    p GAMG
        tolerance        1e-10;
        relTol           0;
        smoother         DIC; //GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    Ua PBiCG
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0.5;
    Ub PBiCG
        tolerance        1e-05;
        relTol           0;
    alpha PBiCG
        tolerance        1e-10;
        relTol           0;
    beta PBiCG
        tolerance        1e-10;
        relTol           0;
    Ha PBiCG
        tolerance        1e-5;
        relTol           0;
    Hb PBiCG
        tolerance        1e-5;
        relTol           0;
    DS PBiCG
        tolerance        1e-5;
        relTol           0;
    Theta PBiCG
        tolerance        1e-05;
        relTol           0;
    k PBiCG
        tolerance        1e-05;
        relTol           0;
    epsilon PBiCG
        tolerance        1e-05;
        relTol           0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      2;
    correctAlpha    no;
    pRefCell        0;
    pRefValue       0.0;
relaxationFactors
    alpha           0.3;
    DS              0.3;
    p               0.3;
    Ua              0.3;
    Ub              0.3;
    Ha              0.3;
    Hb              0.3;
However, my simulation crashed during the first time step and i get this error message:
GAMG:  Solving for p, Initial residual = 1, Final residual = 5.7155e-11, No Iterations 93
--> FOAM FATAL ERROR:
previous iteration field
IOobject: volScalarField p "/home/michta/OpenFOAM/michta-1.7.x/run/EulerEulerBoilingFoam/EulerEulerBoilingFoam/referenceCase/0"
  not stored.  Use field.storePrevIter() at start of iteration.
    From function GeometricField<Type, PatchField, GeoMesh>::prevIter() const
    in file /home/michta/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/GeometricField.C at line 863.
FOAM aborting
Could someone explain me what is happening? I checked the OF User Guide but did not find any answer..
Thanks in advance!
Best,
/Edy
Edy is offline   Reply With Quote
Old   October 20, 2010, 13:18
Ben K
benk is on a distinguished road
You may have other problems as well, but in order to use damping factors, you need to store the previous solution. Just place:
FIELD.storePrevIter();
in your solver before solving for the equation.
benk is offline   Reply With Quote
Old   October 20, 2010, 13:22
Edy
Thanks for your answer. But i applied the relaxation on the equation instead of applying it directly on the field, it should work as well, right?
Here is my piece of code :
        fvScalarMatrix pEqn
            fvm::laplacian(Dp, p) == fvc::div(phi)
        pEqn.setReference(pRefCell, pRefValue);
        pEqn.relax();
        pEqn.solve();
I think this should work too, dont you think?
/Edy
Old   October 20, 2010, 13:24
Edy
Because for the other fields (velocity, enthalpy, k, epsilon), i also apply the relaxation on the equation, not directly on the field, and I do not have this error message...
Old   October 21, 2010, 08:59
Ben K
Hmm...you're right...I'm not sure what the problem is. Maybe try underrelaxing the other way to see if that works?
Old   October 21, 2010, 09:15
Edy
Hi!
Your way works, mine does not, i dont understand why...
However even with this underrelaxation, my simulation crashed, so i will check my code, once again....
Thanks for the help!
Best
/Edy
Old   March 21, 2013, 12:38
Question
hz283 is on a distinguished road
Hi All,
I also had a problem about the underrelax factor in openfoam. In my simulation case, I used k-epsilon and rhoSimplecFoam. However, for the relaxation factors of k and epsilon, I need to reduce the factors to very small, less than 0.1. And the iteration step is zero. If I slightly increase the relaxation factors, the simulation will blow up due to large k or epsilon.
Does anybody know what is the underlying reason behind this problem?
Originally Posted by Edy View Post
Hi Foamers,
solvers
    p GAMG
        tolerance        1e-10;
        relTol           0;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        mergeLevels      1;
    Ua PBiCG
        tolerance        1e-05;
        relTol           0.5;
    Ub PBiCG
        tolerance        1e-05;
        relTol           0;
    alpha PBiCG
        tolerance        1e-10;
        relTol           0;
    beta PBiCG
        tolerance        1e-10;
        relTol           0;
    Ha PBiCG
        tolerance        1e-5;
        relTol           0;
    Hb PBiCG
        tolerance        1e-5;
        relTol           0;
    DS PBiCG
        tolerance        1e-5;
        relTol           0;
    Theta PBiCG
        tolerance        1e-05;
        relTol           0;
    k PBiCG
        tolerance        1e-05;
        relTol           0;
    epsilon PBiCG
        tolerance        1e-05;
        relTol           0;
PISO
    nCorrectors     2;
    nAlphaCorr      2;
    correctAlpha    no;
    pRefCell        0;
    pRefValue       0.0;
relaxationFactors
    alpha           0.3;
    DS              0.3;
    p               0.3;
    Ua              0.3;
    Ub              0.3;
    Ha              0.3;
    Hb              0.3;
FOAM aborting
Thanks in advance!
Best,
/Edy
hz283 is offline   Reply With Quote
Old   August 8, 2013, 03:01
Anne Gerdes
Anne Lincke is on a distinguished road
You have to insert
HTML Code:
p.storePrevIter();
I found this is missing in a bug report.
So try to insert it before
HTML Code:
 #include "pEqn.H"
Anne Lincke is offline   Reply With Quote
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
Fluent VOF Volume of Fluid Realistic Solution Problem wormik FLUENT 3 June 21, 2009 07:04
Discretization problem in Solution controls Tamm FLUENT 0 July 15, 2005 07:07
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Symmetric problem - Asymmetric prediction Mark Main CFD Forum 14 January 29, 2001 13:21
