Why can cacheAgglomeration in GAMG work
Old   October 23, 2010, 05:23
Default Why can cacheAgglomeration in GAMG work
sebi is on a distinguished road
Hello everybody,
I'm working with LES using OpenFOAMs GAMG to solve the pressure equation in PISO. After looking at the function of GAMG's parameters I'm wondering why cacheAgglomeration works.
I mean, it seems to me that if I set this to true GAMG uses the agglomeration it found in time step 1 for each further timestep. According to my basic multigrid knowledge this should only work if the structure of the matrix GAMG has to solve does not change or only a little bit.
As it seems to work fine for at least most situations this seems to be true. But I'm quite unsatisfied with using something just because it seems to be true. I'd prefer to know why the matrix's structure does'nt change so that GAMG can exploit it. Does anybody here have an idea about that or might give me a guess where I might find some information about it ?
Thank you very much,
Sebi
sebi is offline   Reply With Quote
How to work with constant pressure? Martin Siemens 2 February 25, 2009 13:23
Getting FoamX to work shaun OpenFOAM Installation 12 March 23, 2007 08:55
work related to brake study of a vehical aero Siemens 3 November 23, 2006 07:43
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
