error: expected `}' at end of input
Old   November 13, 2010, 03:18
Unhappy error: expected `}' at end of input
Farshad
Farshad_Noravesh is on a distinguished road
I tried to compile steadyreactingFoam solver as described in http://openfoamwiki.net/index.php/Co...teReactingFoam
by using wmake libso
it compiles and gives me the following errors:
alternateSteadyReactingFoam.C:39:31: error: hCombustionThermo.H: No such file or directory
alternateSteadyReactingFoam.C:40:44: error: compressible/RASModel/RASModel.H: No such file or directory
alternateSteadyReactingFoam.C:41:37: error: alternateChemistryModel.H: No such file or directory
In file included from /home/farshad3/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude/ODEChemistryModel.H:220,
from /home/farshad3/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude/chemistrySolver.H:39,
from alternateSteadyReactingFoam.C:42:
/home/farshad3/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude/ODEChemistryModel.C:29:29: error: reactingMixture.H: No such file or directory
alternateSteadyReactingFoam.C:55:44: error: readEnvironmentalProperties.H: No such file or directory
Farshad_Noravesh is offline   Reply With Quote
Old   November 14, 2010, 23:32
Nakul
nakul is on a distinguished road
Check your options file in make folder.
Remove the LinuxGccDPOpt folder and again try to compile.
nakul is offline   Reply With Quote
Old   November 15, 2010, 04:36
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
This solver currently only compiles with 1.5. You're trying with 1.6
gschaider is offline   Reply With Quote
Old   November 17, 2010, 03:39
Default which class is changed?
Farshad
Dear gschaider,
Thanks for your help. Do you know which class has been changed in openfoam1.6?
Kind Regards,
Farshad
Old   November 17, 2010, 05:28
Assistant Moderator
Bernhard Gschaider
Dear gschaider,
Kind Regards,
Farshad
Almost everything that is relevant for this in $FOAM_SRC/thermophysicalModels
Sorry
Old   November 18, 2010, 01:29
Unhappy 118: error: ‘__getdelim’ was not declared in this scope
Farshad
I used OpenFOAM1.5 for steadyreactingfoam solver but now i have some other compiling errors:
[farshad@farshad2 alternateChemistryModels]$ wclean
[farshad@farshad2 alternateChemistryModels]$ wmake libso
Making dependency list for source file OpenFOAM/chemistryModelProxy.C
Making dependency list for source file OpenFOAM/localTimeChemistryModelProxy.C
Making dependency list for source file alternateChemistryModel.C
SOURCE=OpenFOAM/chemistryModelProxy.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/combustion/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/chemistryModel/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/ODE/lnInclude -IlnInclude -I. -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/chemistryModelProxy.o
In file included from /usr/include/stdio.h:929,
from /home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/cstdio:50,
from /home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/bits/char_traits.h:48,
from /home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/string:47,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/string.H:51,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/word.H:44,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/fileName.H:48,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/IOobject.H:69,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/regIOobject.H:42,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricField.H:43,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricScalarField.H:39,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricFields.H:35,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/volFields.H:38,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude/basicThermo.H:40,
from /home/farshad/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/combustion/lnInclude/hCombustionThermo.H:40,
from lnInclude/alternateChemistryModel.H:43,
from OpenFOAM/chemistryModelProxy.H:43,
from OpenFOAM/chemistryModelProxy.C:32:
/usr/include/bits/stdio.h: In function ‘__ssize_t getline(char**, size_t*, FILE*)’:
/usr/include/bits/stdio.h:118: error: ‘__getdelim’ was not declared in this scope
In file included from /home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/bits/localefwd.h:47,
from /home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/string:50,
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h: At global scope:
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h:57: error: ‘uselocale’ was not declared in this scope
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h:57: error: invalid type in declaration before ‘;’ token
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h: In function ‘int std::__convert_from_v(__locale_struct* const&, char*, int, const char*, ...)’:
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h:77: error: ‘__gnu_cxx::__uselocale’ cannot be used as a function
/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1/x86_64-unknown-linux-gnu/bits/c++locale.h:102: error: ‘__gnu_cxx::__uselocale’ cannot be used as a function
make: *** [Make/linux64GccDPOpt/chemistryModelProxy.o] Error 1
please help me
Thanks
Old   November 18, 2010, 10:37
Assistant Moderator
Bernhard Gschaider
After a quick glance I'd say that headers from the OF-compiler (/home/farshad/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../include/c++/4.3.1) and system headers (/usr/include) are being mixed. That would be a general problem of your installation. Try compiling something else to verify.
Bernhard
please help me
Thanks
Old   November 18, 2010, 12:41
Default createFields.H:91: error: ‘alternateChemistryModel’ was not declared in this scope
Farshad
Dear Bernhard,
I did foamInstalationTest and it says my installation is correct.
Executing /home/farshad/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: farshad2
OS: Linux version 2.6.33.3-85.fc13.x86_64
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/farshad/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/farshad/OpenFOAM/farshad-1.5 yes no
$WM_THIRD_PARTY_DIR /home/farshad/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/farshad/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR .../farshad/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...FOAM/farshad-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
gzip 1.3.13 /usr/bin/gzip
tar 1.22 /bin/tar
icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_farshad2 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
done.
Thanks
Old   November 19, 2010, 08:39
Assistant Moderator
Bernhard Gschaider
Dear Bernhard,
This program only does some very basic tests. For instance it checks whether a gcc/g++ is found, but not whether it works.
Have you tried compiling ANYTHING else (preferably OF related but it is my suspicion that a simple HelloWorld.cpp would fail too) using that setup and was it successful
Bernhard
Old   December 12, 2012, 04:27
Anne Gerdes
Anne Lincke is on a distinguished road
Dear all,
since our cluster was updated, I cannot compile any Foam-solvers any more. I obtain a similiar error message as above
HTML Code:
~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible> cd simpleFoam/
~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/simpleFoam> ls
convergenceCheck.H  createFields.H  initConvergenceCheck.H  Make  nutWallFunctionConstantYPlus  omegaWallFunctionConstantYPlus  pEqn.H  simpleFoam.C  simpleFoam.C~  simpleFoam.dep  UEqn.H
~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/simpleFoam> wclean
~/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/simpleFoam> wmake
Making dependency list for source file simpleFoam.C
Making dependency list for source file nutWallFunctionConstantYPlus/nutWallFunctionConstantYPlusFvPatchScalarField.C
Making dependency list for source file omegaWallFunctionConstantYPlus/omegaWallFunctionConstantYPlusFvPatchScalarField.C
SOURCE=simpleFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/RAS/RASModel     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/transportModels     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/singlePhaseTransportModel     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/simpleFoam.o
In file included from /home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/bits/localefwd.h:42,
                 from /home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/string:45,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/string.H:51,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/word.H:43,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/int.H:39,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/label.H:58,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/labelList.H:35,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/Pstream.H:43,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/OPstream.H:35,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from simpleFoam.C:32:
/home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:52: Fehler: »uselocale« wurde in diesem Gültigkeitsbereich nicht definiert
/home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:52: Fehler: invalid type in declaration before »;« token
/home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h: In function »int std::__convert_from_v(__locale_struct* const&, char*, int, const char*, ...)«:
/home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:72: Fehler: »__gnu_cxx::__uselocale« kann nicht als Funktion verwendet werden
/home/lincke/OpenFOAM/ThirdParty-1.7.0/platforms/linux64/gcc-4.4.4/lib/gcc/x86_64-unknown-linux-gnu/4.4.4/../../../../include/c++/4.4.4/x86_64-unknown-linux-gnu/bits/c++locale.h:97: Fehler: »__gnu_cxx::__uselocale« kann nicht als Funktion verwendet werden
/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readSIMPLEControls.H: In function »int main(int, char**)«:
/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readSIMPLEControls.H:6: Warnung: Variable »momentumPredictor« wird nicht verwendet
/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readSIMPLEControls.H:9: Warnung: Variable »transonic« wird nicht verwendet
make: *** [Make/linux64GccDPOpt/simpleFoam.o] Fehler 1
Any help is appreciated!
Edit: The operating system was recently updated to Suse Enterprise 11.2.
I assume that my problems are related to this...
Thank you.
Anne
Anne Lincke is offline   Reply With Quote
Old   December 12, 2012, 06:01
Anne Gerdes
In this thread I found out, that the reason for my error was that the gcc delivered by the Third Party was built by an older operating system.
http://www.cfd-online.com/Forums/ope...of1-7-1-a.html
Switching to system-compiler in etc/settings.sh, like suggested in the thread, led to another error
HTML Code:
make[2]: Entering directory `/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/porousSimpleFoam'
make[2]: »/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousSimpleFoam« ist bereits aktualisiert.
make[2]: Leaving directory `/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/porousSimpleFoam'
make[2]: Entering directory `/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/shallowWaterFoam'
make[2]: »/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/shallowWaterFoam« ist bereits aktualisiert.
make[2]: Leaving directory `/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/shallowWaterFoam'
make[2]: Entering directory `/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/solvers/incompressible/simpleFoam'
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/RAS/RASModel     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/transportModels     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/singlePhaseTransportModel     -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/lincke/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/simpleFoam.o Make/linux64GccDPOpt/nutWallFunctionConstantYPlusFvPatchScalarField.o Make/linux64GccDPOpt/omegaWallFunctionConstantYPlusFvPatchScalarField.o -L/home/lincke/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt \
      -lincompressibleRASModels     -lincompressibleTransportModels     -lfiniteVolume -lOpenFOAM -liberty -ldl   -lm -o /home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/simpleFoam
/usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty
collect2: ld gab 1 als Ende-Status zurück
make[2]: *** [/home/lincke/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/simpleFoam] Fehler 1
I keep on finding a solution for this problem.
Do you have any ideas? Maybe some packages missing?
Thank you.
Anne
Old   December 12, 2012, 06:22
Anne Gerdes
It's me again - hope that this is not annoying for anyone.
In this thread is stated, that I need the binutils-devel package.
http://www.cfd-online.com/Forums/ope...d-liberty.html
As soon as I have installed it (unfortunately I am not able to do this myself) I will give some feedback if it helps.
Regards
Anne
Old   December 14, 2012, 04:21
Anne Gerdes
The missing package binutils-devel was the solution for the compilation problems.
This is also stated here
http://www.cfd-online.com/Forums/ope...er-3d0-3e.html
and here
http://www.idurun.com/?p=329
Sorry for being redundant.
Regards
Anne
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
