using setFields Dict
Old   November 15, 2010, 16:54
Default using setFields Dict
Sandeep
gandesk is on a distinguished road
As per the dam example in the below link, the requirement is to create a rectangle block setFields. How to create other shapes?? Is there any documentation for creating other required shapes.
http://www.openfoam.com/docs/user/da...hp#x7-500002.3
First of all I didnot understand how did he define the rectangle block in the above example. It would be great if anyone can help me in that.
Also I would like to create a semi circular shape for my case in my 2-D Axisymmetric domain. My domain is in the shape of a wedge to consider axi symmetric case. I am including my blockMeshDict file if you want to look at my mesh.
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(-2 0 0)
(0 0 0)
(-2 1.5 -0.0327457)
(0 1.5 -0.0327457)
(-2 1.5 0.0327457)
(0 1.5 0.0327457)
blocks
hex (0 1 3 2 0 1 5 4) (100 75 1) simpleGrading (1 1 1)
edges
patches
patch side
(0 0 4 2)
patch up
(2 4 5 3)
wall Fixedwall
(1 3 5 1)
empty axis
(0 1 1 0)
wedge front
(0 1 5 4)
wedge back
(0 2 3 1)
mergePatchPairs
Any help would be greatly appreciated!!
gandesk is offline   Reply With Quote
Old   November 16, 2010, 02:39
colinB is on a distinguished road
Good Morning,
the box is created actually very easy.
They use two corner points (X Y Z) of the box they want to have, which
are not neighbours.
example:
box (-50 0 -30) (220 90 6.5)
this dscribes a box with the length in x direction of 270 m in y direction with 90 m and in z direction with 36.5 m
for a sphere I'm not 100% shure but you coulkd give it a try:
sphere ( X Y Z) r with r as the radius.
I got this idea from the sHMD file where you can define a searchableBox
which is defined the same way like the box above and they offer also the searchableRegion sphere so this is why I came up with the idea.
hope that helps
regards
Colin
colinB is offline   Reply With Quote
Problem with setFields: "wrong token type - expected word" svevo OpenFOAM Pre-Processing 11 September 26, 2020 04:02
InterFoam - setFields for a non-rectangular 3D domain Ak_cfd OpenFOAM Running, Solving & CFD 24 July 25, 2020 21:16
SetFields runs with no errors but doesnbt change fields adamsview OpenFOAM Pre-Processing 3 December 12, 2014 21:03
question on setFields fijinx OpenFOAM Running, Solving & CFD 1 February 15, 2010 15:07
InterDyMFoam and problem with setFields chris_sev OpenFOAM Running, Solving & CFD 1 March 23, 2009 21:23
