November 28, 2010, 04:21 |
LRR(Launder-Reece-Rodi RSTM) turbulent model
Dear Foamers,
I want use LRR turbulent model but i didn't find any sample in tutorial files. I don't know how is its properties which should be set. Any suggestion will be appreciated. Best, |
January 17, 2011, 09:57 |
any success
Roman Thiele
Rep Power: 20 |
Hej,
did you have any success?
~roman |
January 17, 2011, 10:33 |
missing field R
Roman Thiele
Rep Power: 20 |
what is the field R that the calculation requires?
~roman |
January 17, 2011, 11:02 |
Roman Thiele
Rep Power: 20 |
thank you very much, I will try this and come back to this here when I have a result.
~roman |
January 20, 2011, 10:51 |
Roman Thiele
Rep Power: 20 |
it seems to work with those boundary conditions, givig approximately the same results as the non-reynolds stress models. the results are slightly improved over the standard k-epsilon
~roman |
August 7, 2013, 06:49 |
Refer to Literature
#9 |
Dr. B T KANNAN
Rep Power: 14 |
Dear Maysam,
Kindly refer to the RSM Assessment, Disadvantages in Versteeg & Malalasekara "Introduction to CFD", where it has been mentioned. "In some flows RSM performs just as poorly as k-epsilon model " -- BTK |
October 8, 2013, 23:28 |
LRR CASE FILE - Reg
#11 |
Dr. B T KANNAN
Rep Power: 14 |
Dear skeptik,
Thats good to hear. If you don`t mind, can you upload your LRR case in zipped format for reference. I am using LRR for Jet flows and I am finding difficulty in convergence and some other problems. So it would be helpful if I go through some converged cases. By that hope I can figure out what is going wrong in my simulations. Thanks in advance. -- KANNAN |
October 11, 2013, 16:48 |
#12 |
Rep Power: 15 |
Hi maysmech,
The evaluation of the turbulence model is not that straightforward! Mesh resolution and wall modelling strategy is quite critical for the conclusions of the simulations results. In any case, if there is no high strain in your flow, I cannot see the advantage of using a highly expensive turbulence model like RSM. For a large number of applications, the isotropic assumption is fair enough. Regards, |
October 15, 2013, 01:20 |
LRR axisymmetric jet
#14 |
Dr. B T KANNAN
Rep Power: 14 |
Dear Skeptik,
I used almost the same conditions as you used, but for axisymmetric jet case i am finding difficulties in convergence and getting physically possible solutions -- KANNAN |
October 15, 2013, 01:42 |
#15 | |
But, possibly, bad convergence and non-physically solutions were reasoned by wrong boundary conditions. What is your case? Can you publish it?
practice makes perfect |
October 18, 2013, 00:32 |
Lrr case
#16 |
Dr. B T KANNAN
Rep Power: 14 |
Dear Skeptik,
Here is the first case which i tried. http://www.cfd-online.com/Forums/ope...ess-model.html -- KANNAN |
November 7, 2013, 16:05 |
#17 |
Jason Dale
Rep Power: 17 |
Hi there skeptik,
Thank you very much for you cyclone download, I also wanted to try out LRR for a cyclone so your post was very useful. I was wondering, did you ever manage to verify the results on your cyclone? I ran your case first with simpleFoam with no turbulence and then with LRR activated. The velocity plot in the z-plane (which Im assuming is the tangential velocity profile?) still appears to be a non Rankine Vortex like this one for K-e. http://www.waset.org/journals/waset/v59/v59-328.pdf Whereas I am hoping RSM/LRR looks like this one...which is good enough for what I am currently doing http://www.cfd.com.au/cfd_conf12/PDFs/040KAR.pdf What do you think? Any comments appreciated. Best Regards Jason |
November 8, 2013, 00:08 |
#18 | |
About my case. The velosity profile was not correct. But at least RSM results were better than k-eps. Sorry, I can't remember what was right and what was wrong exactly. My cyclone was just a test-case, i've used third-party mesh. May be problem in initial conditions or in the mesh discretisation. At least about that case i'd say that mesh needs to be refined in near-wall region. For instance by 'refineWallLayer" function. Also as i remember there was tetra-mesh. It could be converted by polyDualMesh which reduces mesh size. Finally i didn't try to change fvSchemes.
November 8, 2013, 00:13 |
Another pic about RSM
#19 |
Here you can see differences.
Vortexes are little bit bigger and have little bit higher frequency. But not so high as in experimental case. a10_comp2.jpg
November 8, 2013, 04:52 |
#20 |
Jason Dale
Rep Power: 17 |
Hi again,
Thanks for the reply, I'm testing a snappy mesh with layers but I think the mesh is a little too coarse in the middle for my liking. So, I will build a pure hex mesh similar to the two cited papers and begin again. BR Jason |
Turbulent SST model | fergal | CFX | 13 | November 2, 2010 18:15 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
difference of the laminar and turbulent model | duaiduaihu | FLUENT | 0 | August 13, 2010 23:40 |
Turbulent Model Problem | yeeking86 | ANSYS | 1 | September 30, 2009 10:40 |
Turbulent model in 2D calculations | Francisco Saldarriaga | Main CFD Forum | 1 | August 10, 1999 23:10 |
