Exception en virgule flottante
Old   January 16, 2011, 08:13
Thumbs up [RESOLVED] Exception en virgule flottante
William Tougeron
taalf is on a distinguished road
Hello everybody,
I'm proud to post my first comment in this forum . I don't speak English so good so I apologize for every English mistakes .
And, to show how much I am motivated, I will put pictures in my post : I set a good example, isn't it ?
Ok, I'm a false beginner in OpenFOAM that I study for my Final Project and it happens something that I don't understand and that I very would like to solve.
My problem is that when I make a coarse blockMesh geometry for a own icoFoam case, it works, but when I use a finer mesh, it makes an "Exception en virgule flottante" during calculation after very few first iterations.
Here is my coarse case (a 2D case with 2 "empty" boundary conditions and only one cell in the z direction) :
with, in my transportProperties file :
transportModel  Newtonian;
nu              nu [0 2 -1 0 0 0 0] 1e-06;
and, in my controlDict file :
application     icoFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1;
deltaT          0.001;
writeControl    timeStep;
writeInterval   100;
and the results :
Pretty good, isn't it ?
Then, I tried to use a finer mesh by only modifying the simpleGrading values in the blockMeshDict:
but this happens when I launch icoFoam after deleting the old time directories (0 0.1 0.2 etc.) :
Time = 0.011
Courant Number mean: 1.01727e+34 max: 7.44368e+37
DILUPBiCG:  Solving for Ux, Initial residual = 5.77125e-09, Final residual = 5.77125e-09, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 2.41172e-09, Final residual = 2.41172e-09, No Iterations 0
#0  Foam::error:: printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam:: DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#4  Foam:: DICPreconditioner:: DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#5  Foam::lduMatrix:: preconditioner::addsymMatrixConstructorToTable<Foam:: DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#6  Foam::lduMatrix:: preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#7  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#8  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libfiniteVolume.so"
 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/icoFoam"
#10  __libc_start_main in "/lib/libc.so.6"
#11
Exception en point flottant
Even if I reduce the time between iterations :
deltaT          0.0000001;
it stops after few iterations with the same error.
My extraordinary happiness when I computed my first case totally collapsed when I realized I wasn't able to redo it with fine mesh !
Does somebody have an idea ?
taalf is offline   Reply With Quote
Old   January 17, 2011, 05:47
Olivier
olivierG is on a distinguished road
hello,
Check your Co number:1e34 max !
My guess i a bad boundary condition: give boundary + fvSchemes for more info.
regards,
olivier
olivierG is offline   Reply With Quote
Old   January 17, 2011, 06:44
William Tougeron
Yes, the curent number is awesome ! But I think it is due to a solver problem because my theoretical curent number should be very low, as the max velocity is around 0.025 m/s and the size of my cells is about 0.025 m, so :
C0 = dt * |U| / dx => C0 = 0.001 * 0.025 / 0.025 = 0.001 = C0
Here are my files :
constant/polyMesh/blockMeshDict :
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.com               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters    1    ;
vertices (
(    0    0    0    )    //    0
(    2    0    0    )    //    1
(    3    0    0    )    //    2
(    3    0.5    0    )    //    3
(    2    0.5    0    )    //    4
(    0    0.5    0    )    //    5
(    0    1    0    )    //    6
(    2    1    0    )    //    7
(    0    0    0.1    )    //    8
(    2    0    0.1    )    //    9
(    3    0    0.1    )    //    10
(    3    0.5    0.1    )    //    11
(    2    0.5    0.1    )    //    12
(    0    0.5    0.1    )    //    13
(    0    1    0.1    )    //    14
(    2    1    0.1    )    //    15
blocks (
hex (    0    1    4    5    8    9    12    13    )
(    80    20    1    )
simpleGrading (    1    1    1    )
hex (    5    4    7    6    13    12    15    14    )
(    80    20    1    )
hex (    1    2    3    4    9    10    11    12    )
(    40    20    1    )
Edges (
patches (
empty
frontAndBack (
(    0    1    4    5    )
(    5    4    7    6    )
(    1    2    3    4    )
(    8    9    12    13    )
(    13    12    15    14    )
(    9    10    11    12    )
wall
walls (
(    0    8    9    1    )
(    1    9    10    2    )
(    6    7    15    14    )
(    4    3    11    12    )
(    12    15    7    4    )
patch
inlet (
(    0    5    13    8    )
(    5    6    14    13    )
patch
outlet (
(    10    11    3    2    )
mergePatchPairs (
0/p:
|  \\    /   O peration     | Version:  1.4                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
// Field Dictionary
FoamFile
    version         2.0;
    format          ascii;
    root            "/home/william";
    case            "default";
    instance        "0";
    local           "";
    class           volScalarField;
    object          p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    walls
        type            zeroGradient;
    frontAndBack
        type            empty;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value            uniform 0;
0/U:
// Field Dictionary
FoamFile
    version         2.0;
    format          ascii;
    case            "default";
    instance        "0";
    local           "";
    class           volVectorField;
    object          U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.01 0 0);
boundaryField
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    frontAndBack
        type            empty;
    inlet
        type            fixedValue;
        value           uniform (0.01 0 0);
    outlet
        type            zeroGradient;
system/fvSchemes :
// FoamX Case Dictionary.
FoamFile
    version         2.0;
    format          ascii;
    case            "default";
    instance        "system";
    local           "";
    class           dictionary;
    object          fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         Gauss upwind;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
And, just in case :
constant/TransportProperties:
FoamFile
    version         2.0;
    format          ascii;
    case            "default";
    instance        "constant";
    local           "";
    class           dictionary;
    object          transportProperties;
CrossPowerLawCoeffs
    nu0             nu0 [0 2 -1 0 0 0 0] 1.48e-05;
    nuInf           nuInf [0 2 -1 0 0 0 0] 1.48e-05;
    m               m [0 0 1 0 0 0 0] 1.225;
    n               n [0 0 0 0 0 0 0] 1;
BirdCarreauCoeffs
    nu0             nu0 [0 2 -1 0 0 0 0] 1e-06;
    nuInf           nuInf [0 2 -1 0 0 0 0] 1e-06;
    k               k [0 0 1 0 0 0 0] 0;
system/controlDict:
FoamFile
    version         2.0;
    format          ascii;
    case            "default";
    instance        "system";
    local           "";
    class           dictionary;
    object          controlDict;
startTime       0;
stopAt          endTime;
endTime         1;
deltaT          0.001;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
runTimeModifiable yes;
functions
system/fvSolution:
FoamFile
    version         2.0;
    format          ascii;
    case            "default";
    instance        "system";
    local           "";
    class           dictionary;
    object          fvSolution;
solvers
     p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
    k               PBiCG
        tolerance       1e-05;
        relTol          0;
    epsilon         PBiCG
        tolerance       1e-05;
        relTol          0;
    R               PBiCG
        tolerance       1e-05;
        relTol          0;
    nuTilda         PBiCG
        tolerance       1e-05;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
SIMPLE
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    p               0.2;
    U               0.2;
    k               0.7;
    epsilon         0.7;
    R               0.7;
    nuTilda         0.7;
Old   January 17, 2011, 07:08
Christian Lucas
Chris Lucas is on a distinguished road
you use a transient solver with a steady state ddt scheme.
Either use a different ddt scheme (e.g. Euler) or a steadyState solver (e.g. simpleFoam)
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   January 17, 2011, 07:25
William Tougeron
Thank you very much, guys ! It works perfectly !
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
Cannot Open .sim (Floating Point Exception) trex930 STAR-CCM+ 1 July 30, 2010 06:51
turbFoam floating point exception and k-epsilon Hectux OpenFOAM Running, Solving & CFD 4 April 28, 2009 07:10
"exception : return code 139" june Siemens 0 January 8, 2008 20:20
