Calculating the cosine of a Foam::scalar field
Old   January 20, 2011, 07:58
Default Calculating the cosine of a Foam::scalar field
RoE
Roland Engberg
RoE is on a distinguished road
Hi!
I'm trying to calculate a smoothed Dirac delta function (volScalarField deltaSmooth) from a volScalarField phiLS with the following code:
forAll(deltaSmooth, i)
if (mag(phiLS[i])<epsLS.value())
deltaSmooth[i] = (1 + cos(pi*phiLS[i]/epsLS.value()))/(2*epsLS.value());
else
deltaSmooth[i] = 0.0;
However, I get the following compilation error:
levelSet.C:88: error: call of overloaded ‘cos(Foam::scalar)’ is ambiguous
/usr/include/bits/mathcalls.h:64: note: candidates are: double cos(double)
/opt/openfoam171/src/OpenFOAM/lnInclude/dimensionedScalar.H:76: note: Foam::dimensionedScalar Foam::cos(const Foam::dimensionedScalar&)
/opt/openfoam171/src/OpenFOAM/lnInclude/Scalar.H:238: note: Foam::doubleScalar Foam::cos(Foam::doubleScalar)
/opt/openfoam171/src/OpenFOAM/lnInclude/Scalar.H:238: note: Foam::floatScalar Foam::cos(Foam::floatScalar)
I also tried phiLS[i].value but without success...
Thanks for any advice!
Roland
RoE is offline   Reply With Quote
Old   January 20, 2011, 08:13
Martin
MartinB will become famous soon enough
Hi Roland,
try Foam::cos(...) instead of cos(...)
Martin
MartinB is offline   Reply With Quote
Old   January 20, 2011, 08:15
RoE
Roland Engberg
Hi Martin,
it works!
Thanks a bunch!!
Roland
Old   January 20, 2011, 08:49
Alton Luder III
sleepdeprivation is on a distinguished road
OpenFOAM overloads the cos function. Check namespace issues.
Try Foam::cos(), and then test it to make sure its doing what you want.
I'm not sure why it can't decide if its a doubleScalar or floatScalar, that's usually picked at compile time.
sleepdeprivation is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
LiftDrag coefficient in LES fabian_korn OpenFOAM Post-Processing 1 September 22, 2008 02:34
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Problems calculating field gh with interFoam cricke OpenFOAM Running, Solving & CFD 0 December 10, 2007 07:17
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
