Help! problems in calculating forces with SimpleFoam |
Davide Lupo Conti
Rep Power: 16 ![]() |
Hello Everyone!
I'm testing simpleFoam (OF 1.7) on the classic NACA 0012. To obtain forces on the airfoil I use the following commands in the controlDict: functions ( forces { type forces; functionObjectLibs ("libforces.so"); //Lib to load patches (wing); // change to your patch name rhoInf 1.225; //Reference density for fluid CofR (0.15 0 0); //Origin for moment calculations outputControl outputTime; } forceCoeffs { type forceCoeffs; functionObjectLibs ("libforces.so"); patches (wing); //change to your patch name rhoInf 1.225; CofR (0 0 0); liftDir (0 1 0); dragDir (1 0 0); pitchAxis (0 0 0); magUInf 55.5; lRef 0.6; Aref 1; outputControl outputTime; } ); When I launch the run, this warning message is given and no forces/forces.dat is made (the run goes without any problem) the same commands work perfectly on interFoam.. can anyone help me? thanks! Starting time loop --> FOAM Warning : From function void forces::read(const dictionary& dict) in file forces/forces.C at line 277 Could not find U, p or rho in database. De-activating forces. --> FOAM Warning : From function void forces::read(const dictionary& dict) in file forces/forces.C at line 277 Could not find U, p or rho in database. De-activating forces. Time = 1 |
Philippose Rajan
Rep Power: 25 ![]() |
A Good Morning to you :-)! You are getting this warning, and the force calculations are subsequently disabled because you are missing one line in your forces function definition... you need to change your function definition to: Code:
functions ( forces { type forces; functionObjectLibs ("libforces.so"); //Lib to load patches (wing); // change to your patch name rhoInf 1.225; //Reference density for fluid rhoName rhoInf; CofR (0.15 0 0); //Origin for moment calculations outputControl outputTime; } forceCoeffs { type forceCoeffs; functionObjectLibs ("libforces.so"); patches (wing); //change to your patch name rhoInf 1.225; rhoName rhoInf; CofR (0 0 0); liftDir (0 1 0); dragDir (1 0 0); pitchAxis (0 0 0); magUInf 55.5; lRef 0.6; Aref 1; outputControl outputTime; } ); Hope this helps! Have a great day ahead! Philippose |
Davide Lupo Conti
YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!
it works fine now! thanks a lot!!!! just wondering why the same lines worked fine on the interFoam solver... Thanks again! DL |
Suraj Garad
Rep Power: 8 ![]() |
hi,
I have clearly mentioned and tried both but it didn't work for me. I am having openfoam 2112. rhoName rhoInf; rho rhoInf; rhoInf 1.0; |
forces, simplefoam |
SimpleFoam convergence problems | brahim | OpenFOAM Running, Solving & CFD | 20 | June 9, 2015 09:09 |
Forces calculation | fusij | OpenFOAM | 4 | October 29, 2010 11:38 |
Forces and drag coeffs in simpleFoam | milos | OpenFOAM Post-Processing | 7 | December 16, 2009 09:49 |
Strange results from interFoam solution converges but sum of all forces not equal to zero | nicasch | OpenFOAM Running, Solving & CFD | 0 | April 15, 2008 02:01 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
