Help! problems in calculating forces with SimpleFoam
Old   January 26, 2011, 17:27
Default Help! problems in calculating forces with SimpleFoam
DLC
Davide Lupo Conti
DLC is on a distinguished road
Hello Everyone!
I'm testing simpleFoam (OF 1.7) on the classic NACA 0012. To obtain forces on the airfoil I use the following commands in the controlDict:
functions
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (wing); // change to your patch name
rhoInf 1.225; //Reference density for fluid
CofR (0.15 0 0); //Origin for moment calculations
outputControl outputTime;
forceCoeffs
type forceCoeffs;
patches (wing); //change to your patch name
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 55.5;
lRef 0.6;
Aref 1;
When I launch the run, this warning message is given and no forces/forces.dat is made (the run goes without any problem)
the same commands work perfectly on interFoam..
can anyone help me?
thanks!
Starting time loop
--> FOAM Warning :
From function void forces::read(const dictionary& dict)
in file forces/forces.C at line 277
Could not find U, p or rho in database.
De-activating forces.
--> FOAM Warning :
Time = 1
DLC is offline   Reply With Quote
Old   January 27, 2011, 01:23
Philippose Rajan
philippose will become famous soon enough
A Good Morning to you :-)!
You are getting this warning, and the force calculations are subsequently disabled because you are missing one line in your forces function definition... you need to change your function definition to:
functions
     forces
         type forces;
           rhoName rhoInf;
     forceCoeffs
         type forceCoeffs;
         rhoInf 1.225;
           rhoName rhoInf;
         CofR (0 0 0);
         liftDir (0 1 0);
         dragDir (1 0 0);
         pitchAxis (0 0 0);
         magUInf 55.5;
         lRef 0.6;
         Aref 1;
Hope this helps!
Have a great day ahead!
Philippose
philippose is offline   Reply With Quote
Old   January 27, 2011, 18:22
DLC
Davide Lupo Conti
YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!
it works fine now!
thanks a lot!!!!
just wondering why the same lines worked fine on the interFoam solver...
Thanks again!
DL
Old   April 25, 2022, 23:43
Suraj Garad
surajk.garad101 is on a distinguished road
hi,
I have clearly mentioned and tried both but it didn't work for me. I am having openfoam 2112.
rhoName rhoInf;
rho rhoInf;
rhoInf 1.0;
surajk.garad101 is offline   Reply With Quote
forces, simplefoam
SimpleFoam convergence problems brahim OpenFOAM Running, Solving & CFD 20 June 9, 2015 09:09
Forces calculation fusij OpenFOAM 4 October 29, 2010 11:38
Forces and drag coeffs in simpleFoam milos OpenFOAM Post-Processing 7 December 16, 2009 09:49
Strange results from interFoam solution converges but sum of all forces not equal to zero nicasch OpenFOAM Running, Solving & CFD 0 April 15, 2008 02:01
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 14:09
