February 8, 2011, 16:46 |
boundray conditions in OpenFoam
yu
Rep Power: 15 |
Hello all,
I have a mesh generated from netgen and is now converted into foam format using netgenNeutralToFoam command. I ran a checkMesh and got the following. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-21131bcbd876 Exec : checkMesh Date : Feb 08 2011 Time : 13:43:22 Host : tribe.cse.ucdavis.edu PID : 25031 Case : /home/yuhou/my_foam_test_dir/test_runs/lam_pipe nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 21203 faces: 213440 internal faces: 197952 cells: 102848 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 102848 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology patch0 0 0 ok (empty) patch1 14720 7408 ok (non-closed singly connected) patch2 384 217 ok (non-closed singly connected) patch3 384 217 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-15.2205 -12.5436 0) (7.77949 10.4564 224) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (6.97395e-16 4.61931e-17 2.7422e-19) OK. Max cell openness = 3.15752e-16 OK. Max aspect ratio = 8.26039 OK. Minumum face area = 0.574487. Maximum face area = 5.89857. Face area magnitudes OK. Min volume = 0.256933. Max volume = 2.45927. Total volume = 92844. Cell volumes OK. Mesh non-orthogonality Max: 71.363 average: 31.0839 *Number of severely non-orthogonal faces: 14. Non-orthogonality check OK. <<Writing 14 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 0.759258 OK. Mesh OK. End I tried to ran simpleFoam solver for this (this is just a pipe flow) but the code crashed. give --> FOAM FATAL IO ERROR: keyword patch0 is undefined in dictionary "/home/yuhou/my_foam_test_dir/test_runs/lam_pipe/0/p::boundaryField" file: /home/yuhou/my_foam_test_dir/test_runs/lam_pipe/0/p::boundaryField from line 25 to line 46. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 456. FOAM exiting I think it is because I don't have the boundary condition defined. How can I defined the boundary conditions here? Or it has to be defined in netgen? thank you so much. |
February 9, 2011, 14:19 |
Jason G.
Rep Power: 16 |
It appears "patch0" is defined in netgen, but doesn't contain anything.
February 9, 2011, 14:40 |
yu
Rep Power: 15 |
Thanks, Jason. I will going into the patch. Do you know other than define them by index of vertex, is there a better way? and what are the options. I found inlet, outlet, fixwall and such. What happen if I would like to define say a parabolic velocity profile at the inlet or something. Is there are good tutorial on this topic? thank you so much
February 9, 2011, 14:41 |
yu,
define the names of our patches in constant/polyMesh/boundary file. use the same name of the patches to assign your BC's in 0/ directory. that should work for you. guilherme |
February 9, 2011, 14:44 |
yu
Rep Power: 15 |
Thank you Guilherme. I will try it right away.
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
Setting a boundary conditions | mer | OpenFOAM Running, Solving & CFD | 1 | November 24, 2005 13:53 |
