GGI case in 1.6-ext
Old   February 19, 2011, 10:52
Default GGI case in 1.6-ext
Robert
lordvon is on a distinguished road
In 1.6-ext, for a case that works in 1.5-dev, when I use the command 'foamJob -s -p turbDyMFoam', the terminal (OS is Ubuntu 10.04) gives:
Parallel processing using SYSTEMOPENMPI with 4 processors
Executing: mpirun -np 4 /usr/lib/OpenFOAM-1.6-ext/bin/foamExec turbDyMFoam -parallel | tee log
Which is all fine and good, but then nothing else happens (where in 1.5 dev I would see continuous reporting on all of the timesteps as the simulation ran). Furthermore I check the CPU usage and all four cores are unoccupied. So I dont really get an error but it is not working properly.
I installed 1.6-ext via: http://openfoamwiki.net/index.php/In...ucid_10.04_LTS
Under Section 2.3.2.
The only warnings/errors I see when running decomposePar:
Calculating distribution of cells
Selecting decompositionMethod metis
--> FOAM Warning :
    From function min(const UList<Type>&)
    in file /build/buildd/openfoam-1.6-ext-1.6.0/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 342
    empty field, returning zero
And I get the same "error" (the linked thread concludes it is ignorable) when running checkMesh as described here: http://www.cfd-online.com/Forums/ope...m-1-6-ext.html
Any help greatly appreciated. Shout if anything else is needed.
lordvon is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl btgyd OpenFOAM Meshing & Mesh Conversion 1 September 26, 2011 17:24
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 raagh77 OpenFOAM Running, Solving & CFD 0 March 6, 2010 05:11
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
