Test directory missing in OpenFOAM 1.6 ext
Old   March 16, 2011, 13:37
Default Test directory missing in OpenFOAM 1.6 ext
Andrew Ryan
andrewryan is on a distinguished road
Just saw that there is no test directory in $FOAM_APP. Why is this I find them quite helpful.
andrewryan is offline   Reply With Quote
Old   March 20, 2011, 11:48
Hrvoje Jasak
I didn't use this for quite a long time: they are very basic unit tests used in development and there is no need to esu the on regular basis unless you are doing something special.
Now that we use automated public test loops I would like to see all live components tested and kept up to date. Keeping eg dictionary tests live is not sufficient use for the benefit I see - that is why I removed them from the release.
Do you feel like keeping the unit tests up to date and creating a test harness? If so, I will consider re-introducing them.
Hrv
Hrvoje Jasak
Old   March 20, 2011, 15:41
Andrew Ryan
> I didn't use this for quite a long time: they are very basic unit tests used in development and there is > no need to esu the on regular basis unless you are doing something special.
I agree they are very basic, but for somebody unfamiliar with the OpenFOAM Code they can be helpful. Also I just got them from 1.6-dev
> from the release.
I think I read about that somewhere when installing and compiling 1.6-ext, but I haven't found the actual test code. Are there unit tests somewhere?
> introducing them.
Sure. I tried to write some simple unit tests using google's test framework. One thing I didn't understand so far is how to "mock" some of the larger object. For example to test the trackToFace(..) function in Particle.C one would need a mesh with two cells and one Particle object. For now I just loaded the mesh from files, but for this to work the test needs to run from the directory of a case containing the test data.
extended test
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 09:55
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 19:09
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
