Compiling
Old   March 22, 2011, 08:16
Default Compiling
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
What should I do to compile the libraries in my home directory?
I knew that to compile a solver (say for example interFoam.C) in your home directory just add USER in interFoam / Make / files, like:
interFoam.C
EXE = $ (FOAM_USER_APPBIN) / interFoam
when i compile interfoam however I noticed that the libraries that adds are not those of my home. (-I/opt/OpenFOAM....)
Making dependency list for source file interFoam.C
SOURCE=interFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/interFoam.o
/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable ‘transonic’
/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable ‘nOuterCorr’
/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nCorr’
/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:8: warning: unused variable ‘momentumPredictor’
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/interFoam.o -L/opt/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt \
-linterfaceProperties -lincompressibleTransportModels -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/aferrari/OpenFOAM/aferrari-1.7.0/applications/bin/linux64GccDPOpt/interFoam
I would leave clean the original version of OF and make changes in my home directory, so how can I do to include the correct libraries?
Thanks
andrea
Andrea_85 is offline   Reply With Quote
Old   March 22, 2011, 10:36
Andrea Pasquali
andrea.pasquali is on a distinguished road
I like to keep together the old and the new one.
In you case I'll create a new directory "myInterFoam" with myInterFoam.C and Make/file:
myInterFoam.C
EXE = $(FOAM_APPBIN)/myInterFoam
Ciao
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   March 22, 2011, 11:00
Andrea Ferrari
Hi Andrea,
I did not understand very well what you mean. My problem is not compiling myinterFoam.C, the problem is that I do not know how to include "mylibrary".
I have to change myinterFoam/Make/option and add the correct path for "library"?
something like:
EXE_INC = \
// -I$(LIB_SRC)/transportModels \
// -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
// -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
// -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
// -I$(LIB_SRC)/finiteVolume/lnInclude
-I$/home/../transportModels \
-I$/home/../transportModels/incompressible/lnInclude \
-I$/home/../transportModels/interfaceProperties/lnInclude \
-I$/home/../turbulenceModels/incompressible/turbulenceModel \
-I$/home/../finiteVolume/lnInclude
EXE_LIBS = \
-linterfaceProperties \
-lincompressibleTransportModels \
-lincompressibleTurbulenceModel \
-lincompressibleRASModels \
-lincompressibleLESModels \
-lfiniteVolume
Thanks
andrea
Old   March 22, 2011, 11:36
Andrea Pasquali
Hi Andrea,
I understood you want to compile a new interFoam without changing the src.
If you want to use your libs in your new solver I don't know if adding -I$/home/.. it works, you can try.
If you have the .H files of your libs you can copy them in myInterFoam folder and include them in .C file.
Andrea
Andrea Pasquali
Old   March 22, 2011, 11:48
Andrea Ferrari
Thanks for the help.
I need to include a new interfaceProperties.H. So you say that it is enough to put the new interfaceProperties.C and interfaceProperties.H in myinterFoam directory and then use #include" " from interFoam.C.
I have to change the Make/option file? Can i delete the line
to be sure that i'm using the new library ?
Thanks
andrea
Old   March 22, 2011, 12:07
Andrea Pasquali
You can try.
Or also you can compile your myInterfaceProperties lib under src/transportModels with "wmake libso" and check in lib you have:
libmyInterfaceProperties.so
Then you compile myInterFoam with
-I$(LIB_SRC)/transportModels/myInterfaceProperties/lnInclude \
in option file
Andrea
Andrea Pasquali
Old   March 22, 2011, 12:52
Andrea Ferrari
Ok, i did it and it runs.
Thank you very much
andrea
compiling icoStructFoam error using OF1.7 mhassani OpenFOAM Installation 7 June 11, 2012 09:22
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
error msg when compiling user fortran Ollimarc CFX 0 March 13, 2008 18:16
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Discussing UDF and C++ Compiling Big Stone FLUENT 9 April 12, 2004 15:07
