multiregionfoam + blockmesh + region property
Old   March 23, 2011, 06:03
Default multiregionfoam + blockmesh + region property
Alpesh
alvora is on a distinguished road
hello friends,
I understood the multiregionHeater problem. In that tutorial, the all geometry is generated by using makeCellsets.setset file.
My question is:
I want to simulate the sphere inside the cube (3-D case). But by sphereToCell command are not giving perfect sphere shapr becasue is consider the all cell which are included in given redius. hence, I have to make geometry by using blockMeshDict.
But, before that I want to simulate 2-D case.
I defined the rectanguler plate with hole. but I also meshed the hole because i want to define as solid.
How can I define these different regions within blockmeshDict file?
thanx alt in advance
regards
Alpesh
alvora is offline   Reply With Quote
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
