March 24, 2011, 02:12 |
a problem in drag coefficient calculating
Maryam Mousazadeh
Rep Power: 15 |
Hello foamers;
I want to calculate drag coefficient on each walls of a cube with unit dimension which is located in a flat plate. The inlet velocity components are (1,0,0) and the density of fluid is 0.1; I add the following code to controlDict : functions { forces { type forceCoeffs; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 1; patches ( top ); pName p; UName U; log true; rhoInf 0.1; CofR (0 0 0 ); liftDir ( 0 0 0 ); dragDir ( 1 0 0 ); pitchAxis ( 0 0 0 ); magUInf 1; lRef 1; Aref 1; } } But the result isn't true. Would you tell me the mistake? Thanks; |
March 20, 2013, 12:11 |
Cd calculation
Emad Tandis
Rep Power: 15 |
Hi
Do you use OpenFoam software for your simulation? |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
lift & drag coefficient on airfoil | n. natik | FLUENT | 8 | March 31, 2015 19:02 |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 11:03 |
coefficient drag | JEHERZ | CFX | 5 | February 9, 2012 06:28 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
