Pressure limit in the recirculation zone
Old   April 4, 2011, 16:58
Default Pressure limit in the recirculation zone
Luigi
Hìr0 is on a distinguished road
I try to simulate a combustion chamber with a step upstream of the injector. The air enters the combustion at M=2.79, T=1200K, and p=101325Pa; I initialized all domain with the inlet condition of the air flow and chemistry is off. Near the step the air is subjected to a strong expansion and a recirculation zone occurs, there pressure goes down as the temperature (<0) and this causes out of temperature range error. How can I solve this problem? I'm trying a fourth order for grad(p) but I don't think it will be useful. What about time step and Courant No.? if I set a low under relaxation factor for p? I use a fixed deltat=1e-9 and MaxCo =0.01.
Thank in advance!
Hìr0 is offline   Reply With Quote
Old   April 5, 2011, 08:56
Luigi
Anyone can help me? Maybe the problem is the initial condition of internalField in U.file (1204m/s):
..............===================== H2(30°) =============
..............|| vacuum / ->
..............|| zone / ->
if I initialize the field with U=0 I obtain a strong expansion of H2 (pH2=200000Pa vs pair=101000) => TH2 already low (T=133K) goes down=> janaf error. Any suggestions?
the vaporised zone should be defined as pressure ? WANGHONG FLUENT 2 January 18, 2021 04:38
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Porous Zone: pressure artefacts evrikon OpenFOAM Running, Solving & CFD 3 October 28, 2009 11:12
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
FLOW AROUND A PLATE_NEGATIVE ABSOLUTE PRESSURE???? tania FLUENT 11 March 23, 2004 08:51
