mesh for heat transfer
Old   April 5, 2011, 01:52
Default mesh for heat transfer
tH3f0rC3 is on a distinguished road
I want to know how I should mesh the volume for the heat transfer that should me solved in my case.
There will be heat transfer caused by convection and radiation.
Maybe there should be several layers at the wall.
Maybe the choosen turbulence model "tells" me how to mesh the volume.
Does someone of you has experience in meshing a volume for heat transfer?
Best Regards,
tH3f0rC3
tH3f0rC3 is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
Mesh Mignard FLUENT 2 March 22, 2000 05:12
