volScalarField question
Old   April 23, 2011, 11:23
Default volScalarField question
Adhiraj
adhiraj is on a distinguished road
Hi all,
I am trying to define a new volScalarField mu. I want to use it as a diffusivity in the transport equation. Now since this field is to be calculated, and not solved for, I cannot specify boundary conditions for it. But how do I make sure that the boundary fields also get updated? This would be important in my mind, as the value might need to be interpolated to call faces during use.
It would be very helpful if some one could come up with an answer.
Thanks.
adhiraj is offline   Reply With Quote
Old   April 26, 2011, 09:16
Ben K
benk is on a distinguished road
You can specify boundary conditions for any field. Normally a diffusivity would have zeroGradient boundary conditions but you could also just make them fixedValue and then update the fixedValue boundaries appropriately.
After updating the field, do a:
mu.correctBoundaryConditions();
I think this is only required if you have a zeroGradient boundary condition and you update the internal fields, but I run this command each time I update the field (even if I don't have zeroGradient BCs) just to be safe.
benk is offline   Reply With Quote
Old   April 26, 2011, 10:02
Adhiraj
Thanks for replying. Can you give me a heads up as to what this function does? Like say for example, it takes the vales from the first row of cells at the boundary and puts them at the boundary faces.
Thanks.
Old   April 26, 2011, 10:28
Ben K
Thanks.
I'm pretty sure that's how it works (ie. takes the neighboring cells and copies them to the boundary to ensure the zeroGradient BC). You can check to see if it works by doing something like this:
label wall = mesh.boundaryMesh().findPatchID("INSERT_PATCH_NAME_HERE");
Info << mu.boundaryField()[wall][0] << endl;
mu.correctBoundaryFields();
This will print out the value of your mu field at the boundary for cell index 0 (or any other boundary index you want) before and after updating the boundaries.
I did find this post though: http://www.cfd-online.com/Forums/ope...perations.html which implies it may not work in parallel...but I haven't verified this and it's quite an old post.
Old   January 22, 2013, 07:41
Default correcting internalfield of a not-solving volscalarfield in each time step
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dear benk,
I have a the following variable:
volScalarField diffus
        IOobject
            "diffus",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        lambda/cp
where lambda and cp are volScalarField variables and varies in the fields in each time step.
How can I correct "diffus" before using it?
Thanks,
Mohammad
atoof is offline   Reply With Quote
Problems with creating a volScalarField georlade OpenFOAM Programming & Development 4 December 4, 2016 12:31
Syntax question relating volScalarField sabin.ceuca OpenFOAM Programming & Development 3 April 2, 2015 04:05
Calculate volume average of volScalarField tangd OpenFOAM Running, Solving & CFD 3 May 1, 2013 13:37
A question about the source code of realizableKE.C yuhai OpenFOAM Programming & Development 1 June 26, 2009 08:05
question K.L.Huang Siemens 1 March 29, 2000 04:57
