April 28, 2011, 11:18 |
perturbU in twoPhaseEulerFoam
Charlie
Hi Foamers,
I want to check that the twoPhaseEulerFoam is reliable, and one of the test case is that I set the domain as one fluid (i.e. the beta=1 everywhere). I modified the code to include pressure gradient which can give a designed Re_tau, and If I'm not wrong, when I turn on the k-epsilon model, the wall-function is automatically on. I set the y_plus=50 at the first grid. OK, Maybe too much information. Now the problem is that when I want to use perturbU to introduce some perturbation, I get stuck. The following is the Perturb.C file. perturbU.C I think the problem is Ub.write(), since if I let it print out Ub[celli], it goes well, however, I just can't have the new Ub file in 0/, so what should I do to let the Ub.write() work? Any hint will be highly appreciated! |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 10:48 |
Stratified flow using twoPhaseEulerFoam | karthik1414 | OpenFOAM | 4 | May 4, 2011 05:12 |
stratified horizontal two phase flow usinfg twoPhaseEulerFoam | karthik1414 | OpenFOAM | 0 | April 12, 2011 09:57 |
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 | raagh77 | OpenFOAM Running, Solving & CFD | 0 | March 6, 2010 05:11 |
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 | hemph | OpenFOAM | 3 | December 5, 2009 04:19 |
