gFoam compressible code
Like Tree3Likes
  • 3 Post By praveen
Old   April 29, 2011, 12:28
Default gFoam compressible code
Praveen. C
praveen is on a distinguished road
I have modified rhoCentralFoam so that one can use any flux function. Currently, Lax-Friedrichs and kinetic (kfvs) are available. You can get code here
http://sourceforge.net/projects/gfoam/develop
using svn or get latest tarball from here
http://gfoam.svn.sourceforge.net/viewvc/gfoam/?view=tar
There are three examples included. The obliqueshock and forwardstep cases run fine but there is some problem with the naca case. The case runs but the solution has strange behaviour near airfoil surface. If any of you try this and have some solution to this problem, please let me know.
praveen is offline   Reply With Quote
Old   July 28, 2011, 09:02
Default Any further realization?
TCH
Solarberiden is on a distinguished road
Hi, praveen:
I have reproduced the odd near airfoil surface you mention in the last post, I have tried to solve but without luck, do you have any new idea about how to fix the problem?
Solarberiden is offline   Reply With Quote
Old   July 28, 2011, 12:41
Praveen. C
Based on advice of Luca Gasparini who is one of the original developers of rhoCentralFoam, I used Gamma reconstruction scheme. That improved the solution a lot. It appears that most reconstruction schemes in openfoam do not perform well on triangles/tetrahedra.
interpolationSchemes
	    default          linear;
	    reconstruct(rho) Gamma  1.0;
	    reconstruct(U)   GammaV 1.0;
	    reconstruct(T)   Gamma  1.0;
If this works for you too or you find a better solution, please post about it.
Old   July 29, 2011, 01:29
Default situation alleviation a little bit.
TCH
I'm sorry but the situation is only improved a little bit and there should be some more efficient way to improve the result. My test result have been uploaded in the attachments, please check them out.
The 0004(at 0.02 second) is better than 0007(at 0.035 second). Along the iteration, the flaw has been appeared evidently.
Thanks Praveen.
Last edited by Solarberiden; July 29, 2011 at 01:33. Reason: for detailed comparison of results of at 0.004 and 0.007 time points
Old   July 29, 2011, 02:37
Praveen. C
I get similar results, not fully satisfactory. It might improve with finer grid. It works fine on quad/hex meshes. I dont know enough about reconstruction schemes in openfoam to say what is wrong.
Old   July 29, 2011, 02:42
Default About polyhedrals
TCH
Have you ever tried out some polyhedral mesh on such test case whether the polyhedral mesh would alleviate the reconstruction issues?
Old   October 16, 2011, 06:49
schwermetall is on a distinguished road
Hi Foamers,
has one of you been successful in solving these pressure fluctuations? I have a similar problem and have been able to minimize these fluctuations using cellLimited grad schemes.
My supervisor thinks that this is a so called checker-board instability (I hope I'm not telling something you already know). What I can say for sure is that I have very high fluctuations using a linear scheme and pretty low ones using a cellLimited scheme.
See http://www.cfd-online.com/Forums/ope...eds-1-a-2.html
Would be nice, if you could comment on that, maybe one of you solved the problem.
regards
schwermetall is offline   Reply With Quote
Old   February 8, 2012, 12:56
Ehsan
ehsan is on a distinguished road
Dear All
Could I kindly ask you whether it is possible to solve forward step test with turbulence model and rhoCentralFoam?
Regards
ehsan is offline   Reply With Quote
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
compressible code Linda Main CFD Forum 2 September 22, 2000 22:10
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
Compressible Viscous Code vaidation test cases? Mohammad Kermani Main CFD Forum 2 November 11, 1999 14:22
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 14:34
